Dash Trim removal - carbon fiber repair
Hey all, I was hoping someone could spell out for me how to get the long defrost vent trim pieces off without doing any damage. My car has the factory carbon fiber package and the CF strips the whole length under the windshield are coming unglued. I'm going to try using epoxy and a bunch of clamps to see if I can bond them back down before I go through the expense of getting replacements. Thanks in advance.
dash trims
Well just pull off the A-pillar trims and then the center alarm sensor cover (carefully, due to the little clips always wanting to break).Then you have to loosen the 3 t20 torx side screws on the vents(each side) and pull those straight off, That will give you direct access with a plastic wedge of some sort to evenly distribute the pressure along the dashboard to unclip the defrost panels.You could use your hands to remove the defrost panels as well, it might just take longer...
When you get the trim off, make sure you use a heat gun (sparingly) to get the carbon fiber back into shape. It will bend easily with heat, but it WILL crack if you try to just clamp it down.
I had this issue with my long strips as well. I got them off and tried everything I could think of. Heat gun then letting them sit under a weight. Glues did not do it. So i left them out and painthed where they were black and you can hardly tell they are missing. There is even a CF pattern in the place where they were already.
Funny thing is that my vent corners were pulling up to and I put super glue on those parts, and wedged the corner down with a screwdriver over night and they have yet to pull away.
I had heard you can get the replacement strips up above but they were 700 bucks. I was not going to spend that much on a silly trim piece. Mine looks just fine, and I even have a Gray dash.
Just my .02
Just my .02
Hey could you elaborate a bit on removing the vents at either side? I only see two T20's and with them removed they do not just pop loose. I am wary of pulling too hard on them.
04-28-2022 12:38 AM
Name Brand
11-21-2015 06:06 PM
