Compression/leakdown tests recommended on low mileage p-cars?
Old Aug 24, 2009 | 11:00 AM
NW Dave's Avatar
NW Dave is infamous around these parts
Just curious what the prevailing wisdom here is on this topic. I was told by a local shop that conducts PPIs that an 03 with 22k miles I was looking at didnt' require these tests since it had such low miles. I have seen recommendations however here and on other boards that suggested getting these tests done regardless.
Any truth to the shop's advice? Thanks
Old Aug 24, 2009 | 11:17 AM
ttboost's Avatar
Those 22k miles could be the hardest miles ever put on a motor vehicle. Now the GT1 engine is otherworldly reliable, but, if the oil hasn't been changed in 22k miles, etc...all bets are off...A couple 3 hundred dollars on a $40k-$50k purchase is pretty good piece of mind. Make sure to tell them what YOU want checked...leakdown, ECU dump, etc...do a search here on PPI...
Old Aug 24, 2009 | 02:26 PM
NW Dave's Avatar
Thanks. That's pretty much what I was thinking but great to hear specific confirmation. Much appreciated TT!
Old Aug 24, 2009 | 04:26 PM
ard's Avatar
ard
I would do the PPI in stanges- initially do part 1- if acceptable, and you are inclined to go forward, complete part 2 with the compression/leakdown- and replace the plugs at that time. The added cost is low given what will be exposed. For obvious reasons the deal terms must be concrete so you can minimize the chances of the seller backing out and leaving you holding the bag, or bill, so to speak.
gulf gt
Aug 27, 2015 10:27 AM
Just Cruise
Aug 25, 2015 12:39 PM
Konea420
Aug 25, 2015 09:44 AM
khiroshima
Aug 20, 2015 12:56 PM
