GT700 shutting off
I have had this issue since I purchased the car. It has the Evoms gt700 package. Evomsit software was recently re-flashed , brand new fuel pump, hitachi maf conversion, spark, coils and the car just shuts off after 5 mins of hard acceleration. It restarts right back up with no problems??
The only code from durametric is 33 interior sensor faulty. Really no other codes. I don't know what else to check for?? Any help would be greatly appreciated!! |
Does it actually power down or go into limp mode?
Dead!! Then starts right back up!!
Can it be electrical short? Someone told me ignition switch but I'm not sold!! |
Do some data logging with durametric...there are lots of possibilities and with your package, lots of opportunities...
do u have LWF? my car sometime does the same thing with LWF
Originally Posted by wross996TT
(Post 2568036)
evo/sachs stage 2 clutch.
Dual mass flywheel |
Originally Posted by yllwturbo
(Post 2568065)
you realize that it should not, right? was your car tuned with the lwfw or installed after tuning? |
Does your car die while you're accelerating hard or is this something that happens when you're idling?
Originally Posted by 911GT700
(Post 2568074)
Dual mass flywheel its the LWFW... just deal with it. |
Originally Posted by ReeknHavic
(Post 2568208)
Recently if I drive it hard within 5 min and coming to a stop it dies not in neutral. I've been in 2nd,3rd, you get the ideahilarious I really thought it was the fuel pump but guess not!! |
Originally Posted by MARKSKI@911tuning
(Post 2568218)
it dies when you let off the gas right or put it in neutral right?
Wow, I was hoping it was the fuel pump. Been following your Renntech thread over there on this as my 2001 is doing the same thing. I got to pull the codes with the Durametric right after it died in the driveway the last time without turning the key off. Got faults on the imobilizer. Thinking back on every time it happened, it was always a day after I washed it. I also have an aftermarket stereo. I'm doing the complete wiring check next.
Mine has LWFW, but as OP's case, engine dies under load, lifting on the the throttle, just sitting in driveway idling, just about any time. Hasn't happenede in about 3 weeks. |
Shuts off doing 80? Man that is jacked up! :(
Originally Posted by 2LOW4
(Post 2568282)
