/// EVOMS [S-351] 1000 HP Monster Build Begins - Project Name to be Determined \\\
Old Nov 1, 2009 | 03:09 PM
  #106
S-351's Avatar
S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !
David? A bit of help here....This is not really true is it? If it is, I will opt for the Evoms GT800 kit for the same price.
Old Nov 1, 2009 | 03:11 PM
  #107
S-351's Avatar
Originally Posted by Prche951
the mile is only a 3 day event, it takes much longer to go swinging
Work and massive boost leak, that I did not know I had that was giving me po507 and po171 errors. Finally found the problem, I think. Now I need a new tune.
If it was a "MASSIVE" boost leak, why was it so hard to find?
Old Nov 1, 2009 | 03:12 PM
  #108
Prche951's Avatar
for the same price? then what would is the difference?
Old Nov 1, 2009 | 03:13 PM
  #109
S-351's Avatar
With the Evoms kit you get a built engine...
Still waiting on David...$40k for bolt ons cant be true!
Old Nov 1, 2009 | 03:15 PM
  #110
Prche951's Avatar
like the nose on my face, it was to dam obvious. I was looking for something hidden. Funny thing is it came from KPG in his quest to help me out, and I never thought about having size issues.
Old Nov 1, 2009 | 03:17 PM
  #111
Prche951's Avatar
WOW, now that is a smokin deal. $40k, for a built engine and GT30/IC/hoses/injectors/etc kit.
Old Nov 1, 2009 | 03:20 PM
  #112
S-351's Avatar
Should KPG come pick up your car?
Old Nov 1, 2009 | 03:27 PM
  #113
Dr_jitsu's Avatar
You have to admit, the Switzer stuff is absolutely first class.
Old Nov 1, 2009 | 03:32 PM
  #114
S-351's Avatar
That it is...I have his Exhaust. ......... For now.
I did almost choke when I called up looking for a new set of tips though.
Old Nov 1, 2009 | 03:42 PM
  #115
Prche951's Avatar
I hope not to be ready for an engine build for sometime. But that is a very fair price. And I am in full agreement that at those power levels an engine build is warranted.
Old Nov 1, 2009 | 03:49 PM
  #116
ttboost's Avatar
D, what was your p0507 problem. Dropped my motor and can't find anything amiss...
Old Nov 1, 2009 | 04:00 PM
  #117
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
Congrats S351! I can't wait to see the beast next mile. Didn't get a chance to meet you at this one (if you were there). EVOMS will take BAD *** care of you that's for sure!!!!
Old Nov 1, 2009 | 04:04 PM
  #118
Prche951's Avatar
vacuum side leak through the turbo inlet area from oversized clamp that would not tighten onto compressor. on both sides.
Mike, I am going to do a full pressure test of the entire engine from intake all the way to exhaust. I don't want anything amiss when I turn up the boost. Have you done that yet?
Old Nov 1, 2009 | 04:41 PM
  #119
ttboost's Avatar
I did a boost leak test days before the Mile. I lowered the engine and removed the intake yesterday and looked for loose hoses and the like. I checked all the IC hoses and turbo inlet and outlet hoses that I could get to without removing the bumper? I didn't check the IC hose connection behind the rear bumper. I'm sure it's good, but I guess I will have to do another boost leak check before I do anything else.
Old Nov 1, 2009 | 08:46 PM
  #120
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
Originally Posted by topgun
The owner of EVOMS doesn't have to jump into the other non-EVOMS threads.... his top customers always do it for him
When I started my build 20 years ago, I went with internals before my car ended up at Evoms...It's what I wanted ....If I wanted to be the fastest I would got 35..(top Dog).
It's not an Evoms thing...If you want to run big power you need at least rods, Evoms, Proto, BBI, ETC.....IMO
I agree when you talk about BIG power... but I think many of us are discussing MEDIUM-big power here... like 650-750whp on stock rods... which many are pushing right now... we just have to watch and see how they last!
