Idle oil check question...
Old Nov 2, 2009 | 06:48 PM
Almo's Avatar
Almo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant future
Keep in mind, I am getting the oil changed Saturday, would do it myself but for the price, it isn't worth the hassle.
Regarding the question, checked the oil tonight after the car warmed up and it shows 2 solid blocks with the others empty.
Is this due to oil being pumped through the motor during idle and will show minimal in the sump being read or is there supposed to be more blocks showing up as solid ones? Getting ready to go grab the manual but thought I would ask just to be safe.
Bottom line, trying to figure out if I need to add a couple qts before I drive the 35 miles to get the oil changed.
Thanks for any help.
Cheers,
Allen
Old Nov 2, 2009 | 07:13 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
yes these cars suck down oil sometimes with hard pulls pushing oil through the seals and past the rings sometimes.
your low on oil at this point, need to be two bars below the top arrow
Old Nov 2, 2009 | 07:24 PM
wross996TT's Avatar
Each bar is ~.25 Qt. I think you will be just fine to get to the oil change appointment. Many folks run several bars below top.
Old Nov 2, 2009 | 07:25 PM
Almo's Avatar
Thanks gents, really appreciate it!
Old Nov 2, 2009 | 07:26 PM
yea probably fine to head over n get changed.
Old Nov 2, 2009 | 07:29 PM
Almo's Avatar
Ok, I might add a qt for safe keeps.
Old Nov 2, 2009 | 07:39 PM
2LOW4's Avatar
2LOW4 is infamous around these parts
A quart is probably too much. I believe the whole guage, all the bars, represents 1 liter. May be able to squeeze a quart in with only one bar left.
Old Nov 2, 2009 | 08:13 PM
Almo's Avatar
Thanks!
rzmnco
Cayenne 955/957
Oct 7, 2025 03:12 PM
PV=nRT.
Sep 9, 2022 06:06 PM
Paintballzen
Oct 10, 2020 12:22 PM
Fester
Sep 8, 2015 09:35 AM
AdPock
Ferrari
Sep 1, 2015 10:13 PM
