Can a non-X50 car with stock ECU hit 0.9 bar?
Old Nov 6, 2009 | 11:25 AM
PeterK's Avatar
PeterK is infamous around these parts
The car I just bought have some mods. It has an agency power exhaust with high-flow cats and an K&N filter in a stock air box. Previous owner said that this is as far as the mods went.
However, on the few drives I've taken I noticed that the boost gets up to 0.8-0.9 bars. I wonder if the car has a flashed ECU and/or aftermarket diverters?
Reason I'm asking is that I'm going to buy extended warranty for it and rather than the ECU in stock form to avoid any hassle in case repairs are needed.
Old Nov 6, 2009 | 11:34 AM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
i used to see 0.9 on mine when it was stock
Old Nov 6, 2009 | 11:37 AM
PeterK's Avatar
Oh good, I was under impression that stock diverters won't hold the pressure above 0.7bar.
Old Nov 6, 2009 | 11:55 AM
buzzm's Avatar
stock diverters will be fine even with a flash, i had them on mine hitting 1.1 all the time, i recently upgraded them though to baileys, i'm sure there are people on here still running the stock bosch ones with mods like a flash etc
Old Nov 6, 2009 | 12:36 PM
wross996TT's Avatar
Are you talking spikes or sustained boost in a WOT pull in third or fourth? Spikes yes, sustained no...
Old Nov 6, 2009 | 12:42 PM
PeterK's Avatar
These were indeed spikes. Sustained boost was somewhere at 0.5-0.6 bar
Old Nov 6, 2009 | 12:44 PM
DJM's Avatar
DJM
DJM is just really niceDJM is just really niceDJM is just really niceDJM is just really nice
After I changed my exhaust to a speedtech I began to see .8 spikes and sustained .7 which is more then I used to see before the exhaust.
Old Nov 6, 2009 | 12:48 PM
PeterK's Avatar
It does make sense, doesn't it? Less back pressure = higher boost.
Old Nov 6, 2009 | 01:03 PM
fdorn's Avatar
fdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud of
Explanation from Tony@epl is spot on
https://www.6speedonline.com/forums/2394361-post2.html
"The 996tt DV's are controlled by a vacuum solenoid thats cycled by the ecu. At high rev's, when you let off the gas quickly, the throttle plate will actually beat the ecu to open the DV's.
This will cause a boost "spike" on the dash that will never reach beyond the throttle plate. "
Old Nov 6, 2009 | 01:21 PM
PyroKerry's Avatar
PyroKerry has a spectacular aura aboutPyroKerry has a spectacular aura about
I would see .7bar sustained stock.
PorscheEnthusiast
Nov 13, 2015 02:23 PM
r_matt_6
Oct 8, 2015 06:07 PM
Sep 1, 2015 03:16 PM
Aug 20, 2015 12:17 PM
