I just love this car
Old Nov 11, 2009 | 02:48 PM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
Well today I decided to take out the front differential to take it apart and see what's inside
I'm halfway done taking it out, and I'm just amazed on how easy it's going. Every bolt comes out like butter thanks to the high quality steel used. Everything makes sense and comes out easily in sequence. These cars were made to be easy to service. I just wish I had room for a lift. I need a taller garage.
Old Nov 11, 2009 | 03:02 PM
ttboost's Avatar
Absolutely positively subscribed. Mine has been out with the same intentions, just other things came up. I'm thinking mine is toast. Keep us (ME) posted!!!
Old Nov 11, 2009 | 03:42 PM
adam699's Avatar
Just got it out. Came out like butter. I initially thought that I'm gonna have to pop the balljoints to get the axleshafts disconnected, but once I took the studs out of the mount i was able to tilt it and get them out. Piece of cake.
I'm gonna start a seperate thread with pics of the teardown and I'll link it.
Old Nov 11, 2009 | 03:47 PM
ttboost's Avatar
I used my buddys lift. Took about 1-1/2 hours total, having never done it before, and also figured out how to NOT ruin the stub axles, so all we have to do is re-grease them and I can have my AWD back in about an hour or so.
Old Nov 11, 2009 | 03:54 PM
adam699's Avatar
I left the shafts intact as I don't plan on running RWD unless the front diff is toast, than I might think about it. I did change a boot once as I pierced it by accident when changing a control arm and it took me a while to figure out how to get the stub out of the axle shaft as most axleshafts use a c clip and these have a pretty advanced "locking" mechanism. Once you know how to do it it's a snap.
Old Nov 11, 2009 | 04:07 PM
adam699's Avatar
Interesting link I found at titan
http://blog.titanmotorsports.com/?p=293
Old Nov 11, 2009 | 04:22 PM
BigBadBen's Avatar
BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !
Mike,
Why do you suspect your diff is toast?
Ben
Old Nov 11, 2009 | 04:26 PM
ttboost's Avatar
Originally Posted by BigBadBen
Mike,
Ben
Not sure Ben. I suspect it is, based on our dyno findings, and I was going to troubleshoot it the way Titan seemingly broke theirs? I was gonna run it on the Mustang dyno (unlocked) to see if the front wheels turned the font drum at all, you know just in 1st or 2nd gear. If the wheels turn the rolers, I'm good. There is so little info out there on this Dif.
Old Nov 11, 2009 | 05:22 PM
fdorn's Avatar
fdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud of
Get one of these....
http://www.youtube.com/watch?v=L5e5c8euXEw
Old Nov 11, 2009 | 05:31 PM
adam699's Avatar
I just took it apart. Breaking it down into the tailshaft, clutch, front case and ring gear assembly literally took 10 minutes. This thing is really a no brainer and you can replace 50% of the bearings without any advanced tools.
As far as the viscous clutch, it's the only thing I wasn't able to take apart (actually my buddy stopped me) as it is welded shut pesky italians (said made in italy) don't want you to know what's inside. If anyone has a broken one they'd like to donate to science, send it my way and I'll take it apart and post pictures.
As far as testing the functionality of the clutch, there is a detailed procedure in the shop manual that tells you how to go about it without breaking it and it had to be assembled on the car to do so. If you don't have it PM me.
Old Nov 11, 2009 | 05:33 PM
adam699's Avatar
Originally Posted by fdorn
I'm really tempted. I showed it to my buddy and I know he's gonna get it for sure as he fixes cars for a living. I myself first need to raise my garage about 4 feet.
Old Nov 11, 2009 | 09:10 PM
adam699's Avatar
Heres the differential thread in case anyone missed it
https://www.6speedonline.com/forums/...ferential.html
PorscheEnthusiast
Nov 13, 2015 02:23 PM
alevine
Nov 4, 2015 10:05 AM
gulf gt
Aug 27, 2015 10:27 AM
Fallbangskid
Aug 21, 2015 02:35 PM
Wheel Experts
American Muscle
Aug 19, 2015 09:07 AM
