01 911 turbo brake job
Old Nov 22, 2009 | 11:37 AM
SPECOPSCPT's Avatar
SPECOPSCPT has a brilliant futureSPECOPSCPT has a brilliant futureSPECOPSCPT has a brilliant futureSPECOPSCPT has a brilliant futureSPECOPSCPT has a brilliant futureSPECOPSCPT has a brilliant futureSPECOPSCPT has a brilliant futureSPECOPSCPT has a brilliant futureSPECOPSCPT has a brilliant futureSPECOPSCPT has a brilliant futureSPECOPSCPT has a brilliant future
Does anyone have an idea of what a reasonable brake job on a 01 911 turbo should cost? Before I get an estimate I want to know what it shoud reasonably cost so I have an idea going into this venture. Thanks.
Old Nov 22, 2009 | 11:44 AM
raineycd's Avatar
Just pads or need rotors as well? Brake fluid flush?
Old Nov 22, 2009 | 01:31 PM
fdorn's Avatar
fdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud of
labor will vary depending on replacing the rotors in addition to the cost of parts
Job02 Front Brakes Labor: $198.00
__________________________________________________ ________________
Replace worn front rotors, pads, hardware kits and sensors.
Disk Left Front 1.0 @ 215.87 =$ 215.87
Disk Right Front 1.0 @ 215.87 =$ 215.87
Hardware Kit 1.0 @ 60.20 =$ 60.20
Brake Pad Set 1.0 @ 256.93 =$ 256.93
Brake Pad Sensor 2.0 @ 18.31 =$ 36.62
Job03 Rear Brakes Labor: $198.00
Replace worn rear brake rotors, pads, hardware kits and
sensors.
Disk Left Rear 1.0 @ 187.84 =$ 187.84
Disk Right Rear 1.0 @ 187.84 =$ 187.84
Mounting kit 1.0 @ 30.32 =$ 30.32
Brake Pad Set 1.0 @ 181.14 =$ 181.14
Job04 Brake Fluid Flush <996> Labor: $99.00
Remove old fluid. Flush, Fill, And Bleed System.
Brake Fluid (high temp 2.0 @ 19.78 =$ 39.56
if you track you car--
Job08 Performance Brake Pads. Labor: $0.00
Customer requests:
1 set front pads - Pagid Yellow
1 set rear pads - Pagid Black
Take with only, no installation required.
Pagid Yellow Front 1.0 @ 334.00 =$ 334.00
Pagid Black Rear 1.0 @ 245.00 =$ 245.00
Old Nov 22, 2009 | 02:05 PM
StuartsPNB's Avatar
StuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to behold
Are you considering aftermarket brakes? or just pads/rotors?
Old Nov 23, 2009 | 08:57 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
Spec you can get parts cheaper through suncoast in you plan to do the work yourself.
and definately put some good fluid in there. if your not seriously beating on the car try the mintrex pads pretty cheap 110$
COBB Tuning
Jan 1, 2025 09:02 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
Vrseis
Aug 20, 2015 07:41 AM
PelicanParts.com
991 Turbo Vendor Classifieds
Aug 18, 2015 03:47 PM
PelicanParts.com
991 Vendor Classifieds
