Horn Beep With Lock/Unlock
#31
So there is a metal connector that connects to a actual plug with cable, right? The only way to mess that up is to not have is plugged in?
I'm pretty sure that I plugged in the two connectors when I reinstalled the console ( 1 connector is for the small light in ash tray, second is for the arm rest lid) so I was assuming that maybe replacing the stock radio cause the beeping, like Aktavate pointed out.
Anyways, next time I have the console out, I'll verify everything was correctly plugged in. Doesn't really bother me too much, so won't be going out of my way to solve this
#32
Yes - it sounds like you have it right - 2 connectors for the console.
There is a brown wire in the radio head unit area that is supposed to be connected to the radio enclosure. If your problem happened after you changed the radio - that's the one.
#33
I used the 2-push of the button last night for the first time and got the horn honk. I also noticed it did not move my seat way back, which is perfect for me since I have never been able to program my memory setting to my key, just to the memory button on the sill.
#36
For HVAC I have codes 35 and 38.
For the Alarm I have codes:
3 Door Lock Barrel Open Actuated
33 Interior Sensor Fault
47 Control Locking Synchronization
60 Central Locking Limit Position
61 Central Locking Limit Position
I also have code 54, but I think that is because of the aftermarket headunit.
I've been ignoring them for the last few years and everything seems to be ok. Thanks for the help.
#37
Yikes!
35 - Could be caused by a missing sensor signal engine speed, outside temp, speed, or sun intensity. (All used for air conditioning operation)
38 - PCM Error
3 - Convertible top fault - defective module.
33 - Passenger compartment monitoring sensor faulty - replace sensor.
47 - Passenger belt buckle / triggering unit for airbag
60 - Central locking limit position - locked not reached. Door lock faulty or control module faulty.
61 - Central locking limit position - unlocked not reached. (same as above)
54 - Tilt sensor (Alarm system activated)
It looks like you could have a few things going on here. You should clear the codes and start over. Hopefully only a few will return and will point to the right issue.
There are quite a few that could cause the horn beep. Perhaps a reset will focus better.
38 - PCM Error
NC 996TT
03-23-2023 06:19 AM
vpr80
03-06-2021 12:11 PM
Mz3bo
10-01-2015 06:32 PM
BarrettG
09-30-2015 02:46 PM
