8 quart oil change?
8 quart oil change?
I had the oil on my 2002 TT done the other day and the tech used 8 quarts with the change. He also replaced the filter and the oil gauge reads full.
Is this the correct amount of oil or was something forgotten?
Factory specs say 8-8.5 liters with oil filter and turbochargers on my 997TT...should be relatively the same for the 996TT.
Just did mine myself, crankcase, oil tank, filter and turbos. 8 quarts put me one bar below the top full mark, warm after a trip around the block.
Wow, that hot oil comes gushing out of that tank. Glad I had gloves on and a pile of newspapers around the drain pan.
Thanks for everyones response. For some reason I thought it required 12 quarts
Since I was trying a new place just wanted to be sure something big was not forgotten
