Best platform for a drag car?
Old 03-22-2010, 12:20 PM
Dr_jitsu's Avatar
Drag racing is fun, and I am committing myself to obedience to all posted speed laws. Thus I am considering building a drag car. I would be more than happy to break 10 flat and trap 145.
Clearly, the 996 nor my M3 are not the best platforms (there is at least one axle breakage everytime I see these cars run on the drag course).
What is the consensus about either a Supra or a Mustang. Either would be an auto.
The argument for a Supra is that they make huge power and I have a great mechanic (Tommy Banh) close by.
Of course the Mustang is probably the best bang for the buck. The car would have to be street drivable.
Old 03-22-2010, 12:24 PM
AWD Motorsports's Avatar
AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !
fox body mustang is pretty cheap to build a 10 second car with.. after about 5 passes in the 10s with an auto it will be very BOOOOORING though..
Mike
Old 03-22-2010, 12:39 PM
ETW 360's Avatar
ETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant future
Fox body would definitely work. I also love seeing 03 Cobra drag cars with auto swaps. 98-02 Camaro/Firebird if you like nitrous. Grand National drag cars are also really cool. Ah so many choices.
Old 03-22-2010, 12:41 PM
ETW 360's Avatar
Mike
This is true though. I have a (C4 auto) Mustang that runs 11.0 and it's become pretty boring unless you get into bracket racing
Old 03-22-2010, 12:53 PM
JD's03tt's Avatar
JD's03tt is on a distinguished road
Fox body easy to make run in the 10's.
Old 03-22-2010, 01:00 PM
Divexxtreme's Avatar
Fox body. Definitely.
Old 03-22-2010, 01:08 PM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
Honda Odessey(room for multi engines)Name:  big yellow face.png
Old 03-22-2010, 01:13 PM
breaking into tens is not a problem... a 18g car will do it...
you might as well just do rods and studs and turn up your car... that probably would be cheaper... tuning and integrity of the set up as it stands is very important... boost leaks, vacuum leaks, coils, plugs, turbos need to be checked regularly... etc... it can be done safely if you have the support...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
ETW 360's Avatar
Here is some inspiration. This is manually shifted with a clutch
http://www.youtube.com/watch?v=IslsDIiywdU
http://www.youtube.com/watch?v=R1W9q...ayer_embedded#
Old 03-22-2010, 01:15 PM
ttboost's Avatar
Geez, one near miss with a ticket and we have a change of life...
Mustang, cheap to go fast and wil be boring after a while...Supra not quite as cheap, wwaayyy faster and will make you a better drive/ricer...er racer, if you keep it a stick.
germeezy1's Avatar
germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !germeezy1 Is a GOD !
Fox body, if you were adventurous you could run in the 10's on a stock block with total mods and car easily under $12k. Or you could buy one already built and set aside a budget for any thing that needs to be done to the car. Plus if you ran with a mild turbo setup you could run an EBC and have a perfectly streetable car that turns into an animal when you need it too.
Old 03-22-2010, 01:17 PM
germeezy1's Avatar
Also for the money you spend on a 10 second Supra if your buying an already built car you can run into the 8's with the Mustang and still have money left over. The Mustang is by far the best choice for a dedicated drag car and you still have lots of money left over for Porsche mods!
Old 03-22-2010, 01:25 PM
Almo's Avatar
Almo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant future
Fox is cheap and rather easy to build but I would recommend an 03/04 Cobra.
Add auto, a twinscrew, fuel pumps, solid axle with a big/little and run 9s all day long.
I did the below with an 03 Cobra.
Basically took a stock cobra and did the following:
Tune only with stock pullies on the stock eaton, no motor work.
K&N drop in filter
Race seats
Rear seat delete
K member
upgrade tranny input shaft
live axle w/31 splines
Spec stage 3 clutch
exhaust
big/little tire
Ran a 11.01 at 126
Added an upper pulley only, an intake, retune with the above combo and took the car to a 10.84 at 129
Added an upper and lower and retune with aforementioned and ran a 10.69 at 128. At this point I believe I had about $14K in the entire car... including a $3K CM six point roll bar.
03/04 Cobra motors and the T-56s are very reliable and take a beating like the GT1 motor... Supra motors as well. 600 to 700 to the wheels is nothing for the 03/04 Cobra motors. Not to mention they have the same brand pistons as the Porsche GT1 motors do.
Old 03-22-2010, 03:29 PM
_Zac's Avatar
_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future_Zac has a brilliant future
Sean I hate to agree with everyone while my car sits in the garrage, but a stock Cobra motor can hold over 1k to the tires. I'd do a turbo kit and a built 6 speed to keep it fun. Toss in the solid axle and it's game on! (trust me I know cause I have one)
A big Kenne Bell like the one I have or a whipple will also net huge power on these cars without sacraficing drivability. The Cobra and the Supra would be my top choices for a Street/Track car, but in the end it's how much do you want to spend and what car better fit's your personality.
Good luck,
_Zac
Old 03-22-2010, 03:37 PM
Mullet's Avatar
Mullet Is a GOD !Mullet Is a GOD !Mullet Is a GOD !Mullet Is a GOD !Mullet Is a GOD !Mullet Is a GOD !Mullet Is a GOD !Mullet Is a GOD !Mullet Is a GOD !Mullet Is a GOD !Mullet Is a GOD !
Ford GT
Quick Reply: Best platform for a drag car?
