-   996 Turbo / GT2 (https://www.6speedonline.com/forums/996-turbo-gt2-2/)
-   -   Car won't start!!!!! (https://www.6speedonline.com/forums/996-turbo-gt2/213933-car-wont-start.html)
PORSCHEFREAK Jun 10, 2010 07:50 PM
So I go into the garage tonight to start my car, turn the key and car won't start. You hear clicking when I turn the key. There is power to the radio and so on. However I did notice my clock had been reset. Anybody else have this problem with your car? Weak battery? Alternator? Starter?
pinoy911tt Jun 10, 2010 08:42 PM
you battery is weak. recharge or get new battery. after charging or getting new battery, check for charging, if ok, check for draws. if no draws, it was just a battery.
raineycd Jun 10, 2010 08:54 PM
Be sure to lock your doors via the key fob to shut more electric draws off...
unterbergamotte Jun 10, 2010 09:21 PM
A Porsche battery lasts a maximum of about 5 years. If you drive just a few miles at a time, it will be less. Many batteries have a sticker with installation date. The symptoms you describe point to low battery charge. I most cases, the battery needs charging or replacing. If the issue returns, have the altonator checked. Pep Boys will do that for free. If its working fine, you might have a electrical draw, possibly aftermarket stereo or similar. If you just don't drive the car very much, buy a trickle charger and you will be fine.
PORSCHEFREAK Jun 10, 2010 09:25 PM
Thanks for the info. I will start with the battery then go from there. The car does not get driven enough so I hope it's just a case of a weak battery.
FAST FWD Jun 11, 2010 12:14 PM
if the car is garaged, get a battery tender to keep the charge up. batteries last a lot longer that way.
PORSCHEFREAK Jun 11, 2010 04:14 PM
Hey guys thanks for your help. It was the battery that was low and caused the car not to start. I definately have to buy a trickle charger now for when the car is sitting.
