996 TT Variocam problems
Old Feb 8, 2005 | 03:37 PM
Q8_TwinTurbo's Avatar
Q8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud of
Hi everyone,
I have a problem with the cam position sensor solenoid !
Whenever i connect the connector to right cam position sensor solenoid, i get rough idling. The car starts shaking as if it has a high lift camshaft in the engine. The electric signal to the solenoid is alwasy on even when the ignition is switched of . I have two different signal readings as the mechanic at my dealer garage has stated after he checked on the Porsche diagnosis tool. Something like 8v on the left side and 12v on the right side. Any help will be appreciated.
Old Feb 8, 2005 | 04:28 PM
retsel75's Avatar
retsel75 is infamous around these parts
Cam Solenoid
I have heard that the 996 and 996tt have had faulty solenoids which advance the cam timing drastically. I'm surprised that your dealer is not aware of the problem and cure. Why don't you E mail Porscheracing@aol.com. He is a Porsche technician here in New York and is aware of the issues, maybe he can help.
Old Feb 13, 2005 | 12:00 AM
tme's Avatar
tme
tme is infamous around these parts
I had a problem with a cam clip.... they had to replace the entire cam because you can't buy the clip alone, it only comes with the cam...... big job... happy it was still under wty
tropicatango
Jun 8, 2025 01:00 PM
2lflat4
Nov 18, 2019 05:05 PM
Jojore9
Sep 30, 2015 05:11 PM
gulf gt
Aug 27, 2015 10:27 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
