Can you disable the brake pad sensors?
My brake pad sensors are broken and im wondering if there`s any way to remove this function and dont have a warninglight? thankfull for any tips
yep you can grab the old sensors from your pads and cut the plug off leaving about an inch of wire. The grab a heat shrink tube, solder the wires, melt the heat shrink and re-attach the plug to the plug on the car....do that times 4 and no warning lights will pop up...
easy job
easy job
easy job
easy job
no probs ...the sensors are actually pretty cheap, but the day I replaced my brakes I didn't want to see any lights so I did the quick fix....and then never ended up going to the dealer to buy the new sensors lol.... :P
easy job
easy job
i have the same problem on my wifes cayenne>>>>
i broke the sensors upon removing the old pads and was too lazy to replace them. so i now get the "brake pads workshop" message when the truck is started. if i were to "bypass" the sensors and connect the 2 wires and heat shrink as mentioned in the previous post will the warning light go away or does it need to be deleted at the dealership?
Great tip!
Just did all four corners of my 03 C4 Cab. Every time I washed the car, the "brake pad" light would come on and stayed on till the brakes were totally dry. Clipped the end off, wrapped them, and put it all back together. Works like a charm! Thanks guys!
I did the same.
Old thread but for those that don't want to have to worry about the sensors every time you change brake pads (often if you track) this is the right solution. I bought new sensors - but until I sell the car - I will not install them. Brake pad changes take less time that removing the wheel this way.
still a puzzle.
The photo was very useful. I just twisted the wires togethe, shrink wrapped and tied to the strut but did not see the dash light go out. i can easily go to soldering or a better connection. Do i need to re-set the light in some way?
ECS Tuning - VW
09-02-2015 09:03 AM
