Notices
Alarm Reset?
Old 08-14-2010, 03:10 PM
Porsche By Ken is a glorious beacon of lightPorsche By Ken is a glorious beacon of lightPorsche By Ken is a glorious beacon of lightPorsche By Ken is a glorious beacon of lightPorsche By Ken is a glorious beacon of lightPorsche By Ken is a glorious beacon of light
Alarm Reset?
I have, what i hope to be a very simple solution to several things that appear to not be working.
#1- the alarm is chirping, indicating something is amiss.
#2- The following items are not working
Power Windows, interior lights, sunroof, right side panel on the center dash (power lock, lighter, and rear defroster), both trunk and engine door lights.
I checked fuses, and this is not the issue, at least not for the windows and sunroof, I stopped checking when neither were blown.
I am hoping this is just a reset of some sorts for the immobilizer (although the lighter and defroster have me worried it could be something bigger)
Background is that the car recently came back from the shop where they said the battery died 3 times and while on dyno it was always hooked to the charger.
Any ideas for a central cause is greatly appreciated.
Thanks in advance for the help!
Old 08-14-2010, 03:36 PM
TURBO ELECTRO's Avatar
TURBO ELECTRO is a jewel in the roughTURBO ELECTRO is a jewel in the roughTURBO ELECTRO is a jewel in the rough
Pull the driver's seat and see if there is an onboard fuse at the alarm/central locking system I can't recall. Also use a digital volt meter and check for power and ground going to the module. Also have you reset the battery and also not just checked the fuses by sight but actually with a volt meter to verify 12 volts is present? Report back with results.
Old 08-15-2010, 12:38 AM
Lacking the tools...
Well, I reset the battery with no luck.
I looked at the bolts for the seat and it's that star/reverse torx head (the kind I don't have).
I dug deeper into the manual and the symptoms do point to the alarm due to the double chirp when pressing the remote.
It also says the remedy is to take to the dealer.
I will be taking it back to the shop that was working on it with the hope that they may be able to correct it.
Old 09-11-2018, 03:05 PM
sbell914 is an unknown quantity at this point
I am having this exact issue. Do you remember the cause?
Old 09-12-2018, 04:46 AM
Atrox's Avatar
Atrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud of
Probably faulty micro switch in door. A good diagnostic scan should pull, but won’t tell which door.
Old 09-13-2018, 11:22 PM
'02996ttx50's Avatar
'02996ttx50 has a reputation beyond repute'02996ttx50 has a reputation beyond repute'02996ttx50 has a reputation beyond repute'02996ttx50 has a reputation beyond repute'02996ttx50 has a reputation beyond repute'02996ttx50 has a reputation beyond repute'02996ttx50 has a reputation beyond repute'02996ttx50 has a reputation beyond repute'02996ttx50 has a reputation beyond repute'02996ttx50 has a reputation beyond repute'02996ttx50 has a reputation beyond repute
hope you sort the issue and also wish you still had available (2) 315/30/18 michi's ps2's at 500 per pair GL.
7thsign
12-12-2015 07:43 PM
slicky rick
10-23-2015 06:53 PM
Needsdecaf
Cayenne 958
10
10-12-2015 03:05 AM
Mz3bo
10-01-2015 06:32 PM
BarrettG
09-30-2015 02:46 PM
Quick Reply: Alarm Reset?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
