Just installed sprint booster and 997 shifter - Review
Here's the part from Suncoast Porsche in Flordia:
http://www.suncoastparts.com/product...de=performance
Pretty good price--its worth every penny!
Hey willie, its the one for $194. It's the perfect balance I find between the stock shifter and a notchy short throw one.
You must understand that if your throttle input is in the right place at the right time, you will be beside yourself on how well the car responds. Its not uncommon for us to hear from our customers that their car feels completely different (but in a good way) It is truely amazing to drive a modern car with zero throttle.
I agree it WOULD be truly amazing to drive a modern car with zero throttle. How's the air going to get into the motor?
The least expensive one is the standard 997 shifter. The more expensive one is the 997 short shifter that is often praised as the best SSK for the 996.
trust me on this one ... get the ssk version and shell out the extra 200 dollars. i went from 996oem to 997oem to 997ssk.
Meh, it's a dc volt amplifier, with selectable gain now. You can get the same effect by simply pushing your gas pedal more. People feel the same change as if they had simply driven with more gas pedal in the first place. If they want to drop a bunch of money on a voltage amplifier instead of just pressing the gas pedal more.. then great! Those people are keeping Sprint Booster in business!
Again the fact remains, Sprint booster is much more advance then what your describing. Our technology is patented and designed to provide the best throttle experience possible. We went in to Sema with this technology and came away with Product of the year, beating out thousands of other products. Sprint Booster is something that once you try it, you get it, you understand the true benefits.
Try it, prove the claim wrong. Our product has a 30 Day return policy if it doesnt work to eliminate the lag in your vehicle return it and tell everyone here on the forum about your experience.
Final point, countless people have tried our product very few if any have a problem with it and return it. Those who try it generally love it. This simply maybe the best mod you will buy for your car in a plug and play form.
Refering to eliminating throttle lag, thank you for point out the typo.
Doesn't sound like the sprint booster gets rid of lag. It sounds like it increases the reaction time of your throttle input, so when you go from easy throttle to stomp to the floor throttle, the response time that the ecu reacts is much faster. That is the lag I think they are talking about. CJV says this is already programmable in motronic? if so, then a tuner can change settings as well to do this. But maybe it is an on off thing in tuning, whereas with this you can have your easy driving reaction throttle and race mode on off switch type response.
IS this what I am understanding or am I missing something.?
What if I don't have any lag? I don't have any issues with my throttle whatsoever. I had a 330ci that was a little quirky, but no issues with my 997 or Cayenne. To say that it improves every car would be a bit of a stretch. I'm sure there are some vehicles that could benefit, but not all. And if I did have an issue, personally I would prefer to get an ecu flash that corrected it and receive the benefits of engine remapping as well. And if I want the pedal to feel "hyper sensitive", I just hit the sport button and it'll do exactly the same thing. Its interesting to hold a constant speed and turn the sport button on and off, the rpms change as the TPS is adjusted for sensitivity.
All that said, at the end of the day no one can force you to try the product. But we are willing to guarantee that you will be satisified with the benefit, or you get your money back. No B.S. Even if your car comes equipped with a sport feature, there is still benefits to be had. This is proven. Verify this with the countless people of different makes and models who have tried sprint booster.
To address your last comment, "Its interesting to hold a constant speed and turn the sport button on and off, the rpms change as the TPS is adjusted for sensitivity."
Again your test would not work to the effect that your looking for because part of the sprint booster advantage is that sprint booster makes changes based on your inputs. holding your foot steady while changing modes defeats the analyzing nature of the product. If you demand power, either WOT or partial throttle, Sprint Booster is designed to analyses what your foot is doing (aka read your mind) and implement a modified signal based one what you desire.
With the two modes, we cover a broader range of customers based on their tastes. Do a good search find a specific application we cover and search sprint booster based on that. And you can see everyones opinion.
http://forums.evolutionm.net/service...sr-review.html is a good example. Even this user found the product to be a great benefit on the track. If you search further you will find real world application tests that may provide you with a more balanced opinion.
I do not know anything about Sprint Booster's system. I'm sure it will be looked into and understood in due time. Sprint Booster said it is patented ....... could I have the patent number to look into what was patented? It could be something new and different, if so I would be interested in exploring it and possibly adding it to our project.
Don't let the Sprint Booster advertiser confuse you. I'd like to dispell the myth:
It does NOT and NEVER will decrease DBW lag. Motronic is still going to do what it does with the throttle valve. The SprintBooster products do NOT intercept or circumvent the signal between the ECU and the throttle body. All it does is amplify the DC Voltage between the pedal and the ECU. There is NO lag there.. NONE. (well aside from the lag of the speed of electricity, which is not accelerated by SprintBooster. )
Claiming that SprintBooster decreases DBW lag is completely and blatantly false advertising. It does no such thing.
The Pedal returns a signal to the ECU, 0-5v DC. What Sprint Booster does is simply amplify the signal, so if you depress your pedal 30%, it might send a signal to the ECU indicating that you pressed it 50%, or 60% or whatever the gain is set to. YOU CAN DO THE SAME THING by simply pressing the gas pedal 50%, or 60% instead of 30%.
So effectively, Sprint Booster reduces the accuracy of your throttle pedal by shortening functional travel of the gas pedal. (Since if pressing the pedal 80% tell the ECU you pressed it 100%, you lost the last 20% of pedal travel doing anything)
It's really quite simple, but Sprint Booster sales and marketing people will tell you it's complicated, or it does this or that... but at the end of the day it's a dc voltage amplifier with selectable gain with a 5v max output.
See through the smoke and mirrors folks!
It does NOT make your car any faster (unless you're phycisally unable to push your pedal 100% by yourself ), it does NOT DBW reduce lag (physically impossible due to it's location and complete separation from motronic).
