X50 @ ~540 P, want 650 - how to get there without ton's of green?
Old Oct 10, 2010 | 08:36 PM
☣MUSCLE☣'s Avatar
☣MUSCLE☣ has a spectacular aura about☣MUSCLE☣ has a spectacular aura about
Originally Posted by OS Inspector
just trying to educate people that a 5bar works but if you push that line there are expensive consequences.
Absolutely...I agree with this.
To SuperCollider: Remember my friend. LOW BOOST
Old Oct 10, 2010 | 08:43 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
these are not my words but check out this info:
The flow from the fuel pump drops off at 5000 RPM's with a 5bar. This means that the injectors go into a fury/high duty cycle to cover the target AFR.
If your stock K24's are running the injectors at 95% duty cycle, at 1.1 to 1.2 bars >>>> how can you think that K24/18G have anything left? 1bar or 1.1bar at 105% duty cycle??????
Doesn't make sense...
Both failures are K24/18G 5 bar systems.
https://www.6speedonline.com/forums/...e-failure.html
https://www.6speedonline.com/forums/...-my-motor.html
500$ injectors and some labor is sure cheaper then 20-30k and not driving your car for a year (me)
Old Oct 10, 2010 | 09:16 PM
☣MUSCLE☣'s Avatar
Wow,
Those are quite nasty.
Markski told me not to run it past .8bar let alone 1.2-1.3!
I am working with him on a setup now. Should be interesting.
Old Oct 11, 2010 | 10:41 AM
Kai@ELITEMS's Avatar
Kai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant future
K24/18Gs, #72 Injectors, EPL Tune will get you around 550whp if you want more add on intercoolers, Aquamist, Inlet Pipes, and Straight Pipes
Old Oct 11, 2010 | 03:14 PM
gsxr1074's Avatar
gsxr1074 is infamous around these parts
Originally Posted by ☣MUSCLE☣
Wow,
I purchased a 2002 turbo with K16's and a Giac flash. Last night I saw 1.1 bar on stock turbos. I do not know if the car has stock injectors, or upgrades such as injectors or a 5 bar kit. Am I fine with the stock injectors?
Old Oct 11, 2010 | 03:26 PM
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
GSXR1074, love the screename. I've got a GSXR too but it's not stroked like yours is. It sounds like you may have a flash since you're seeing 1.1 bar. Even if you do have a flash, you should be fine with stock K16s a stock fpr and injectors.
Old Oct 11, 2010 | 03:49 PM
P2P's Avatar
P2P
P2P is a jewel in the roughP2P is a jewel in the roughP2P is a jewel in the roughP2P is a jewel in the rough
since i'm using the k24/18g with 5bar fbr .. i would not recommend to go with it coz my car is going away over injector duty cycle when i boost up over 1 bar.
Old Oct 11, 2010 | 03:58 PM
jhuang25's Avatar
jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !
That 2nd link was my car. Every car is different, the miles, "type" of miles put on the car etc... but blown motors aren't cheap to repair, so given the money you are looking at right now to upgrade to 18G with supporting mods, the injectors are a no brainer imo. $500 to $700 for injectors. If you decide to skip the injectors, you will be limited to running lower boost. With injectors and some race gas, difference will be night & day and will be so much more worth it. btw, even with injectors, I would only run higher boost on race gas. just my opinion.
Old Oct 12, 2010 | 07:15 AM
MBailey's Avatar
+1 Relatively cheap and safe...
Old Oct 12, 2010 | 08:41 PM
xc17pilot's Avatar
xc17pilot is infamous around these parts
Supercollider
What were your X50 mods that took you from 450 to 540 HP?
Any issues?
Thanks.
Old Oct 12, 2010 | 08:50 PM
Hogapalooza's Avatar
Hogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond repute
Originally Posted by Supercollider
What's the next thing to do to gain another 100 HP? New turbos to replace the K24s I imagine and some more fuel.
Suggestions? I've reached out to my tuner, but wanted to see what the forum has to say.
If you have a X50 then you need Markski @ 911Tuning. He is the KING of K24s and lots of HP for little $.
It goes something like this,
Stock K24's to 18g's
5 bar FPR
BMC filter
ECU tune ( he does protomotive )
Exhaust ( his 3" or something like it )
New DVs
Good luck.
speedsterr
Oct 26, 2015 09:18 AM
4080
Oct 5, 2015 01:44 PM
