Clutch actuator reservoir overfilled?
The reservoir appears to have been overfilled and leaked. I siphoned some off to bring the level down. Could this be a sign of something other than just over filling?
Sorry.
Jon
Yeah, sorry for starting another thread. I should have searched, I preach that all the time. There's a ton of info on the subject.
Guess I'll get on this after I finish with the radiator. That's if I can ever get somebody to ship one that isn't damaged. I have two sitting in my living room waiting to ship back.
I've currently got it happening for the second time....
I'm just siphoning back and forth. Waiting for my clutch replacement upon which I will install the GT2 fix.
I'm told when the slave goes bad it backs Pentosin up causing an overflow of the reservoir in the front of the car. That is the symptom I am experiencing. Porsche has an actual test listed in their repair manual on page 664 that I haven't done yet but am going to by this weekend.
If you are experiencing this also be aware the clutch and power steering share the same Pentosin. If you are overflowing up front, you are probably low in the back, hence Yves' comment. If this is happening to you vntperformance, please PM me.
I would also suggest that you check the screw on cap to the reservoir to make sure that it has not expanded to the extent that it cannot be tightened it down. This happen to mine and I thought the slave was going out. I replaced the cap and have not had a problem with Pentosin leaking from the reservoir.
If your actuator is bad I would expect leaking of the Pentosin to drip from the reservoir and maybe make its way down toward the front axle. I'd be surprised if any ever actually dripped onto the floor. I'd get it up on stands to see where it might be coming from.
If leaking in front you will see it if you just pull the black plastic piece on driver side out and flip it over. It will be noticeable right there in the recess for the cap if it has been leaking.
Slave and accumulator on driver side mounted to tranny housing. Anything on ground between rear tire and door jamb towards middle of car would indicate that kind of leak.
Yes, Pentosin is green...and yes again VERY flamable.
Guys-
I went through THREE slaves/accumulators in under two years. Wonder if changing pressure plates to handle higher hp, system just can't handle it. I finally did the GT2 conversion and absolutely LOVE IT.
Guys-
