Turbo Intake Pipe install
Old 12-29-2010, 06:43 AM
justin8018's Avatar
justin8018 is on a distinguished road
are there any Turbo intake Pipe Kits avail that can be installed without dropping the engine?
I have the manifolds, turbos, Y pipe, Airbox, and Ic pipes all out of the way, and i cant even figure out how to remove the intake pipes without dropping the engine.
Old 12-29-2010, 07:32 AM
MBailey's Avatar
Several tuners have kits but you at least have to lower the engine a few inches to get any access at all.
Old 12-29-2010, 08:59 AM
lower the engine a bit. i am pretty sure you have to cut the stock piping to get it out without lowering the engine all the way.
#TeamAIM
Old 12-29-2010, 09:25 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
it isnt a easy job.... with only lower the engine but it is possible..you have to cut the oem pipe on driverside plus lower the engine a lot...
hard job to cut the pipes and hard job do fixe the clamp behind the engine
Old 12-29-2010, 09:59 AM
Ms4cd's Avatar
Ms4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond repute
It may be better to do this while doing the clutch...
Old 12-29-2010, 06:19 PM
John@SpeedTech's Avatar
winniGT2 knows, he installed our Y-Pipe and turbo hard pipe intake kit himself.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old 12-30-2010, 02:40 PM
AlexN's Avatar
AlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud ofAlexN has much to be proud of
sorry for the noob question, but how bad is it to drop the engine on these cars?
how much can you expect to pay for this job at shop?
Old 12-30-2010, 08:17 PM
Lowering the motor is quick and easy - loosen a couple of bolts. Dropping the engine out takes a few hours and is fairly involved...
2022 Cayenne White
Old 12-30-2010, 09:15 PM
ttboost's Avatar
A lot can be done by just lowering the engine in the car. This will give you almost another 5 or 6 inches at the top of the engine bay. All that is required (all from the bottom) is to loosen the 2 exhaust straps, loosen and remove the 2 engine mount nuts. It's best to support the engine, but it can't fall out if you just let it rest all the way down. Depending on what your doing you may have to remove the bumper cover..again only a few screws up top and below.
Old 12-30-2010, 09:39 PM
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
What about the engine harness?
Old 12-30-2010, 09:41 PM
ttboost's Avatar
Not a problem...not even a factor....engine only drops 5 or 6 inches..
Old 12-31-2010, 09:33 AM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
had to cut my oem stuff..the new pipeing made a huge difference
Old 12-31-2010, 09:55 AM
the trick is to cut the stock out... then maybe use the bendable hose kit so you dont have to deal with all the hard piping....
We sell both just for that very reason..
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
COBB Tuning
01-29-2022 09:42 AM
MadWhip
09-03-2015 02:04 PM
ECS Tuning - VW
08-19-2015 08:58 AM
Quick Reply: Turbo Intake Pipe install
