6Spd member FAST LANE 996tt 996tt s cab, need info?
Anyone familiar with this car, It is a 05 996tt S cab, dark gray almost black, modded and driven very spiritedly to say the least. FAST LANE was a long time contributor to these boards and he is out of NJ. He used to set up many driving meets in the tri-state area before switching boards. I have the opportunity to purchase his car, just looking for info. thanks
Just do a search under his Screen Name and read thru his posts.
i've seen that car at a midnight run before it looked clean. you should check it out since you are close...
A PPI should tell you a lot about a car. Also check carfax but I know sometimes it is not really all that reliable...
Like the others posted before me, You should really go check it out firsthand. That is a lot of $$ to put down to not actually drive it. Having the PPI and carfax helps with peace of mind too. PM if you need a carfax run. My account is still active for a little while longer.
