Has anyone ever installed PSS10's in a 996 GT2?
Old Mar 27, 2011 | 06:00 PM
K24madness's Avatar
K24madness is infamous around these parts
I was told the standard PSS10 for the 996 turbo would not fit. Can someone explain to me the difference between the two?
Old Mar 27, 2011 | 06:01 PM
raineycd's Avatar
I think the fronts are the issues - turbo is AWD and has different suspension up front.
Old Mar 27, 2011 | 06:10 PM
K24madness's Avatar
So it has to do with the lower attachment points of the strut?
Old Mar 27, 2011 | 06:12 PM
raineycd's Avatar
I think so, but I am not sure of exactly what is different, etc.
Old Mar 28, 2011 | 03:03 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
PPS10's are not really a good choice for a GT2 since the fronts won't adjust down to GT2 ride height without shorter springs which causes the shocks to ride on their bump stops. You should focus on coil over system that does not adjust spring height but moves the shock assemble up or down with the remaining in static perchers thereby maintaining full shock travel and allowing both extension and recoil adjustments with no change in spring rate. The stock GT2 suspension is pretty good out out of the box. Unless you plan to spend a lot of money (like 10K) you may not end up with better handling but worse handling.
Old Mar 28, 2011 | 05:34 AM
Blockhed's Avatar
Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !
If you havea good deal on them, get them revalved by bilstein and resprung and you can lower them as low as you want
Old Mar 28, 2011 | 05:42 PM
rossignol24's Avatar
rossignol24 is infamous around these partsrossignol24 is infamous around these parts
Question: What's the stock setup on a 6 gt2? H&R springs and what shocks... I wanna get coilover wrenches so I can lower mine in the front. Thankss.. sorry didn't mean to hi jack your thread
PelicanParts.com
996 Vendor Classifieds
Aug 20, 2015 02:41 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:42 PM
