Clearing CEL's
Old Jun 2, 2011 | 04:08 PM
daytrip00's Avatar
daytrip00 is infamous around these parts
Clearing CEL's
I've been getting P1411 and P0410 CEL codes and am going to attempt swapping out my DV's tonight. I'd like te get this car smogged, and I was wondering if you guys knew if I'd have to clear the codes myself or if the codes would automatically reset if I drive the car around a bit. What do you guys think?
I'll let you know how it goes (if the problem goes away).
Thanks in advance.
Old Jun 2, 2011 | 04:31 PM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
First, for what reason you think it is the DVs? You can get a $50 OBD-II reader and most of them can clear codes. However, after you clear the codes, your car has to go thru a number of cycles (forgot the number) before it is invisible to the smog tech.
Old Jun 2, 2011 | 05:15 PM
daytrip00's Avatar
I've been getting P1411 and P0410 codes. Those almost always indicate a failed Diverter Valve. I'm just wondering if i don't reset the codes if they'll go off by themselves.
Old Jun 2, 2011 | 06:01 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
The manual says that these codes are from the secondary air injection system, one code is for bank one, the other for bank 2. Diverter valves do not appear in the list of possible faults, although I suppose a vacuum leak at the DV's is possible. Here is the list of possible causes from the manual:
♦ Secondary air injection pump is not triggered
♦ Secondary air injection pump does not work
♦ Air supply lines restricted
♦ Electric change-over valve does not function
♦ Air change-over valve does not function
♦ Vacuum system leaking
Old Jun 2, 2011 | 07:30 PM
daytrip00's Avatar
Thanks guys. I've done a great deal of research on on 6speed and rennlist and I've come to the conclusion that at least 90% of the time it's one of the DV's. Once it was actually the spark plugs...
I'm not worried so much about whether the fix is right. I'm more worried about verifying the fix and how to clear the CEL's before my smog test.
Old Jun 2, 2011 | 08:35 PM
ard's Avatar
ard
They will eventually clear, but could take many, many starts.
OTOH, if you clear the codes it will take a while for the readiness monitors to 'set'.
Old Jun 4, 2011 | 11:55 AM
daytrip00's Avatar
In case any google searcher ends up on this page, I replaced the DV's and the problems went away. I plan to have a more detailed writeup on how to make sure your readiness codes get set.
Thanks for all your help guys. 6speed is such a valuable resource!
ModBargains
Oct 13, 2015 03:43 PM
ModBargains
Bentley Vendor Classifieds
Oct 13, 2015 03:42 PM
ModBargains
Lotus Vendor Classifieds
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ModBargains
Oct 13, 2015 03:40 PM
