Time to replace my stoptech rotors...where do i buy it from ?
Old Jun 7, 2011 | 09:52 PM
DNugget991GT3's Avatar
Guys,
I have 355mm stoptech 2 piece floating rotors. the rotors are done (the right more than the left).
the time has come to replace them, so i have two questions.
Should i go for slotted, drilled or a solid and drilled rotor ?
and the 2nd question, where should i buy the rotors from ?
Old Jun 7, 2011 | 10:06 PM
FLY996's Avatar
FLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud of
Zeckhausen Racing (local in NJ)
Old Jun 8, 2011 | 12:30 AM
jspporsche's Avatar
jspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond repute
Slotted. The holes are cool looking but crack easier.
Jim
Old Jun 8, 2011 | 01:04 AM
Turbo Fanatic's Avatar
+1 on that advice
Jim
Old Jun 8, 2011 | 08:23 AM
i have slotted now, and i completely trashed em.
Old Jun 8, 2011 | 08:36 AM
bmoores's Avatar
bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !
Second this! Dave is an absolutely stand up guy. Used to buy from his regularly when I was road racing.
jspporsche's Avatar
That's what happens to rotors. Now there are bad rotors out there. I have no personal experience with Stoptech but they have a good reputation.
Did you warp them? Its important to bed rotors correctly to help prevent this. But if they are just worn thin or grooved, that kind of goes with the territory. Some performance pads willeat rotors quickly and if you don't need them for the track, you can get rotors to last longer.
The only rotors I know of that last a long long time are switching the system over to ceramic. But that's big money. Otherwise, slotted rotors tend to last the longest. Crossdrilled crack very fast under track usage, sometimes the same day you put them on. If I was still going to track events 5-10 times a year, I'd put on ceramic.
Jim
Old Jun 8, 2011 | 08:47 AM
i dont track my car, i only drive it on the street.
with that being said, when i do drive it, i absolutely beat the **** out of it. always late braking.
so the consensus is slotted aye ?
Old Jun 8, 2011 | 08:55 AM
jspporsche's Avatar
Slotted, stock pads. OE pads give the best compromise on cold stopping bite and will take the heat you are giving them.
Jim
Old Jun 8, 2011 | 09:01 AM
jspporsche's Avatar
You might also want to look into cryo treating the rotors. I've heard good things about it. Apparently it realigns the molecular structure of the metal and makes them much stronger. Never tried it myself.
Jim
Old Jun 8, 2011 | 09:51 AM
OE pads wont fit on my calipers. i have stoptech 6 piston calipers.
Old Jun 8, 2011 | 10:08 AM
jspporsche's Avatar
They will have something just like OE. You might want to take some pictures of the rotors and contact them too to discuss what best suits your driving.
Jim
Old Jun 8, 2011 | 10:58 AM
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
Rotors generally do not warp. The vibration you feel is due to uneven deposit of the pad material on the rotor.
Why don't you buy them from Stoptech?
http://www.stoptech.com/Products/rotors.shtml
Old Jun 8, 2011 | 12:43 PM
^i figured maybe i had more options. ideally, ide love to get a 380mm disk but i dont think theyre compatible with my setup
Old Jun 8, 2011 | 03:29 PM
Tim941NYC's Avatar
The last time I seen your rotors they were blue! You track that thing on the streets..
