Rear Tires 315/30 - do these fit stock rim with no adverse issues
Do these fit the stock 18" rims with no adverse issues in performance/handling. Do they provide any advantage other than the overall look?
Is anything needed to make them work with the stock rims - spacers,fender's rolled ??? Thanks!
The contact patch is larger. This is good in dry weather. In rain or snow, the handling will be worse as the weight of the car is distributed over the larger area and the car will hydro-plane easier and skid on snow even worse.
Jim
Jim
Thanks all. So to confirm - just mount and install front and rears at the same time, nothing else needed?
If I do use spacers, what kind should I use and I take it at that point the fenders would need to be rolled?
Just make sure that you change the fronts to the 235/40 size at the same time or you will have issues with the PSM as the tire Rev Per Mile for the rears will not match the fronts.
Correct. Spacers would only make it look better and no rubbing. You can do 7mm front and rear. Some people go 14mm+ with no problems on a lowered car even.
Your car uses an 18x11 with offset (ET) 45 in the rear.
- GT-2 is an 18x12 ET 45. That translates to ET 33 on an 11in wheel. (lower # is more aggressive or outward)
If you used a 7mm spacer with the factory wheel it will make your ET 38. This is less aggressive than what wheel companies like HRE use on an 11in rear wheel. They use 30-35.
In the front you are ET 50 and with a 7mm spacer it will push to 43. 3-5mm less aggressive than most wheel manufacturers use.
It will look better with a set of 7mm front and rear without ANY issues whatsoever.
+1 nice to see you're still into it sam! I'm still looking for a white Z4 ///M if you run into one
To the OP, I'm running a 12" rear wheel with 15mm spacers and 315s (rolled fenders with no rubbing). You'll be fine with stock, 7mm, 15mm and maybe even 21mm spacers if you roll the rear fenders.
Thanks for the info! Any recommendations on where to get the 7mm spacers?
I'll be installing OEM GT2 wheels and GT2 size tires soon, sounds like rolling isn't totally necessary?
You'll probably need to roll the rears with GT2 wheels. I just bought a 2 lb mallet from home depot, covered the striking end with duct tape (a few layers) removed the rear wheels and went to work. Took all of 15 minutes.
I'm sure Dan at Speed Gallery can handle doing for you if it sounds too crazy... it's really pretty simple
Well done though
SharkyShark20
Sep 19, 2015 09:54 PM
JayJayJohn
Sep 17, 2015 05:09 PM
