headlight adjustment
Old Jul 20, 2011 | 01:50 AM
kkswow12's Avatar
kkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nice
hi, is there an adjustment for the whole assembly when installing? the light seems to sit low in the space at the top, the light isn't flush with the body at the top of the fender... seems there should be an adjustment to correct this? thanks, kk
Old Jul 22, 2011 | 04:27 PM
porscheforfun's Avatar
porscheforfun is infamous around these parts
I know you can adjust the beam , but as far flush with the fender I think most of them are below the fender line on top if this is what you are referring to
Old Jul 23, 2011 | 01:58 AM
Slider's Avatar
When correctly installed, the assembly should be in the right place, but if you miss the tracks on the way in, I could see it sitting low. Just remove the whole assembly (it's easy) and reinsert making sure the two lower tabs align with the tracks. All the instructions are in the owner's manual.
Old Jul 23, 2011 | 02:03 PM
kkswow12's Avatar
thanks for the input, i have found how to adjust the whole assembly, there is a plate with the notches for the tabs and it has 3 nut washer adjustable thingys, my hi-tech description... but have adjusted them so that the whole assembly is flush, mo betta...
davetherave
Bentley
Sep 16, 2015 06:30 AM
gpt817
Sep 8, 2015 10:21 AM
midtownlandman
Sep 3, 2015 01:17 PM
