Stage 4 GTR AFR's in race mode
Does anyone with stage 4 GTR have their Air/fuel ratios recorded from a dyno run in race mode with race fuel?
Mine are high, roughly 13.6@5500 RPM (lean) and would like to know if anyone else has experienced this as well TIA |
With race fuel it's really ok to be leaner than the usual mid 12s. It's pretty safe as long as you're running 100 octane or more...
Alex,
I lost 10 HP and 16 lbs of tq after the plenum install maybe starving for fuel up top? |
Maybe you have a boost leak or another issue. The box picked up HP on the GTRs we tested. You need to pull the box and re-establish a baseline then work from there.
Ron...
How did Ken do with his revised setup? |
Originally posted by BCS996TT Ron... How did Ken do with his revised setup? I will let Ken reply I on the other hand need a 5 bar fuel pressure regulator, thanks again Stephen, you always put a smile on my face! |
Always glad to help. That is what I am here for.
| All times are GMT -6. The time now is 05:10 PM. |
