Pressure Testing Car from Turbo intake....cold side of turbo leaking air (videos)
Old Oct 17, 2011 | 03:06 PM
bad107's Avatar
bad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond repute
I pressure tested my car this weekend after I got the 997.2 intercooler replaced (end tank leaking)...thank you Markski for all the tech support!!
I was unable to get the car to hold its pressure, and notice a few small leaks (MAF and diverter valve) and a large leak at the TB. Luckily tightening the clamp around the TB fixed the issue. The car would still not hold pressure and after checking everywhere I notice a lot of air is leaking out of the turbo themselves (also, I know the air goes into the cylinders so some leakage can not be avoided).
I am putting compressed air into the turbo air inlets (which usually receive non-compressed air), so this might not be an issue. I just though these turbos would have came sealed on the cold side as well for $5k.
Thanks!
http://www.youtube.com/watch?v=rPbTcIeDTSQ
http://www.youtube.com/watch?v=rO7T0..._order&list=UL
Old Oct 17, 2011 | 05:22 PM
Tim941NYC's Avatar
Ben,
I smoke test then psi test only to make sure what ever hose connections will not blow off.. Some leakage is acceptable. Some guys even drill small holes were oil blow by pools up. Turbo's do have O-rings not sure why they are leaking by that much.
Old Oct 17, 2011 | 05:34 PM
If they didn't use threadlocker on the bolts of the compressor housing it will leak.. that's if thats where it's coming from... some leakage is Ok but would be nice if it would seal up...
I thought a while back there was a thread about this...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Oct 18, 2011 | 08:41 AM
how did you get the intercooler replaced? local dealer? or dealer you bought it from?
#TeamAIM
Old Oct 18, 2011 | 09:03 AM
pumptech's Avatar
pumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond repute
It wasn't leaking around the bolt holes. On one turbo there was a small focal leak but with a pretty strong jetting leak. The other was leaking the entire circumference of the housing cover plate around the seal. Obviously there is usually a vacuum at this location. I assume now that tial doesn't use thread lock? If this were the case a large percentage of turbos would leak and no one would be able to pressure test correctly without having their out of the box turbos pulled apart and seals redone. I don't believe it, if this were common people trying to pressure test would go nuts and it would be all over the board
Old Oct 18, 2011 | 01:03 PM
bad107's Avatar
I bought them from Sonnen Porsche. I purchased an additional intercooler from Neil @ Sonnen and he is going to credit me once he gets the old one back in the mail and Porsche ok's the warranty exchange.
i lost to a c6 z06 vette with a blower and meth...they are fast!
Old Oct 18, 2011 | 01:11 PM
i ran an LS2 procharged vette on meth here, i got around it nicely.
how long have your ICs been in use?
#TeamAIM
Old Oct 18, 2011 | 01:15 PM
bad107's Avatar
I have had them since february 2011. Porsche gives a 2 year unlimited mile warranty on parts
I had a 200lb passenger, no brake boost and he barely beat me (oh, i also have a tiptronic)
Old Oct 18, 2011 | 01:50 PM
OOoo you got a tippy - you should be doing digs my friend
Tippy+your power = mid 10s ?
#TeamAIM
Old Oct 18, 2011 | 08:33 PM
Tim941NYC's Avatar
I have see these leaks posted before. The area that is leaking is not under vacuum, only the inlet would be under a vacuum (many will say no part of the turbo is under a vacuum). If you take the snail off and lube the O-ring with a petroleum grease and re install it most likely will stop leaking. My experience is that the O-ring gets twisted up during the install and makes it leak.
Old Oct 19, 2011 | 06:50 AM
TiALSport's Avatar
TiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond repute
Leaks at the backplate are completely normal
Old Oct 19, 2011 | 07:46 AM
bad107's Avatar
Are factory turbos sealed?
If not...the real way (for most people) to pressure test their cars would be from the lower boost hose since the turbos leak...
Old Oct 19, 2011 | 07:55 AM
S4corrado996TT's Avatar
S4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really nice
Subscribed! Tks for sharing!
Old Oct 19, 2011 | 08:07 AM
TiALSport's Avatar
nope, nor are most of the other OEM turbos, the only turbos I know of that completely seal (because RTV is used and if you ever needed to get it apart it's a PAIN) are IHI OEM units
Old Oct 19, 2011 | 01:46 PM
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
I don't see a problem with turbos leaking such a little quantity of air.....espetially big turbos. I would say those leaks are orders of magnitude smaller than the air flowed by the compressor at those pressures...
Imo.
