PPI's what do you consider a must do / maybe do?
PPI (Pre purchase inspections)
What do you guys consider to be necessary. I will make a running list to keep this first post pertinent. 1 - Leak down / compression test 2 - Over revs, what else can be checked??? 3 - Transmission, 2nd gear pop out issues 4 - Brakes, Pads and Rotors 5 - Tires / Wheels 6 - Interior condition / Seat wear, any other locations 7 - Body condition / Nicks, dings scratches, any paint history??? |
Clutch - Does it slip? - Has the accumulator gone bad?
Pedals, Floor Mats, and Gear Shifter - Does their wear match what the mileage suggests? Alternator - What does the voltage read? Window operation - Is their any grinding sound, this signals a regulator on it's way out Divertor Valves - Identified by a 'Honking' sound at start-up Spoiler Operation - Any leaking rams, or errors? Check for servicing at regular intervals |
| All times are GMT -6. The time now is 12:17 AM. |
