Coolant pipe repair - now required for DE!
#92
Took car to first driving event Saturday; a fitting on water pump manifold popped out on the drive home from work yesterday. Should have her back together by the weekend if all goes well and my "while Im in there" parts arrive as expected.
#94
Here is what I did while the engine was out (some were done prior):
Coolant pipe fix
Expansion tank
Water pump
Check valves (I thought there was only one, but there are two)
Oil pressure sending unit
Metal turbo oil feed lines checked
Waste gate vacuum lines
5 bar fuel pressure regulator
Clutch kit
Slave cylinder (found it was leaking a bit with the engine removal. Bad news/good news)
Pressure accumulator
Spark plugs
Water hoses
Fuel filter
Air filter
Crankshaft seal
Boost pressure test
Wastegate adjust
Endless brake fluid
Coolant
Throttle body seal
Precision Porsche GT2 deck lid (wing painted matte black)
GT2 deck lid wiring harness
Transponder
Coil packs
Solenoid brackets
Engine mounts (RSS)
Trans mount (997 version)
Multi-rib belt
2nd gear detent
Coolant pipe fix
Expansion tank
Water pump
Clutch kit
Spark plugs
Water hoses
Fuel filter
Air filter
Crankshaft seal
Boost pressure test
Wastegate adjust
Endless brake fluid
Coolant
Throttle body seal
Transponder
Coil packs
Solenoid brackets
Engine mounts (RSS)
Multi-rib belt
2nd gear detent
#95
It sure gives you piece of mind when it's done.
I pinned mine for three reasons.
1. I didn't like all the heat that's generated by welding.
2. I didn't want to do the research to find a competent welder and didn't want to pull the engine again if it leaked.
3. My stock pipes never failed and hadn't leaked.
Later, Steve
Later, Steve
#97
Here is what I did while the engine was out (some were done prior): Coolant pipe fix Expansion tank Water pump Check valves (I thought there was only one, but there are two) Oil pressure sending unit Metal turbo oil feed lines checked Waste gate vacuum lines 5 bar fuel pressure regulator Clutch kit Slave cylinder (found it was leaking a bit with the engine removal. Bad news/good news) Pressure accumulator Spark plugs Water hoses Fuel filter Air filter Crankshaft seal Boost pressure test Wastegate adjust Endless brake fluid Coolant Throttle body seal Precision Porsche GT2 deck lid (wing painted matte black) GT2 deck lid wiring harness Transponder Coil packs Solenoid brackets Engine mounts (RSS) Trans mount (997 version) Multi-rib belt 2nd gear detent
djcooper@rennkit.com
#98
It sure gives you piece of mind when it's done. I pinned mine for three reasons. 1. I didn't like all the heat that's generated by welding. 2. I didn't want to do the research to find a competent welder and didn't want to pull the engine again if it leaked. 3. My stock pipes never failed and hadn't leaked. Later, Steve
<49535443 01000000 10000000 14000000 28000000 c8000000 42475241 01000000 00000000 0a000000 55494163 74697669 7479496e 64696361 746f7256 69657753 74796c65 53746174 75734261 722e3740 32782e70 6e670000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 5c000000 01000000 00000000 4a010000 e9030000 14000000 01000000 00000000 00000000 14000000 28000000 eb030000 1c000000 01000000 00000000 00000000 00000000 00000000 14000000 28000000 ec030000 08000000 00000000 0000803f ee030000 04000000 01000000 4d4c4543 00000000 03000000 3a010000 0e16160e 680100f0 fff0fff0 fff00160 049c3801 f02e6004 cc3801f0 1640042d 98010a00 fc3850fe 4610464b 6e02fb46 2e469946 7f6e0df0 0b461546 d36054ff 3801f608 98084c38 54fa3850 f6084c66 d4080898 011100f0 00084438 54f2660f 69909df3 684c14f7 6e15ff28 013854f2 98013f00 fc684c69 f0132801 604c0b98 010800fc 60540e98 011300f0 5060e061 3804f208 143801f0 0608a068 0419f708 14685062 f0373801 f04a0988 462a9801 0500fc61 d8039801 0400f010 084c4655 60546638 01f6084c 601c3338 54f00638 4cf26010 55080160 043a0801 0844084c 3854f006 684c07ff 08016004 4c280138 54f66e03 fb684c1e ff660038 50f20801 3854f22b 983801f6 08549801 0600fc38 50fa0801 0898384c fe3801f0 023850fe 3801f01e 3990f238 01f0fff0 fff0fff5 e1000600 00000000 0000>
#99
Replacement can be done with the engine in place. The hardest part was getting the oil/water cooler mounting plate off. Required pushing the oil tank out of the way to get to one of the four 10mm mounting bolts. Once the manifold is out, everything is right there.
Rick
Rick
nlakind
11-06-2015 10:15 AM
