Seeing sustained boost of 1.4/1.5bar w/ K16 billets w/fuel kit, EPL dyno tuned,
Old Mar 13, 2012 | 11:53 AM
drhenrock's Avatar
drhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to behold
I have check waste gaits..moving freely, they along with DV's were replaced just over 1 year ago with upgrade, power is steady no change. The 1.5b is at full throttle....it may be me but I don't seem to hear as much bolw off when throttle is cut after full boost???
Old Mar 13, 2012 | 07:47 PM
02turbo996's Avatar
02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future
i'm seeing 1.5bar on my gauge at times with the same setup but logs show 1.4 bar as mine was tuned at.
Old Mar 13, 2012 | 08:23 PM
MBailey's Avatar
My car does that on pump with A28s, so the boost by itself is not a problem. The other half of the equation is timing. You will need to data log to see that but I suspect its not more than 16-17 degrees at redline WOT which has been safe on my car on 93 oct...
Old Mar 15, 2012 | 01:43 PM
drhenrock's Avatar
Thanks, Tony I did. Where exactly should we be looking for a leak?
Originally Posted by Tony@epl
Scott - Call in and speak with Dave. We've seen a number of cars coming in with small leaks in the pressure reference side of the boost control system that have resulted in minor over boost conditions. Im not too worried abotu the boost your seeing, I just dont want it to go much higher.
At 1.4 bar and 16 degrees advance with a28's on a proper set up... your at least 2-3 degrees from MBT and are likely driving up EGT running timing that low. I would be more worried about heat then knock a that point.
Car Feels strong as ever....LOVE IT!!!!
BlackMarketRacing
Dec 8, 2015 01:49 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
Sales@epl
996 Turbo Vendor Classifieds
Sep 7, 2015 02:05 PM
