Fuel gauge reset? Stuck just aboe empty
So I've had my car parked for 4-5 months. I started it a couple times throughout the winter and the fuel gauge always read fine.
So today I go put some gas in it because it's going to the shop next week for spring power ads and such. I put 4 gallons in and the fuel gauge stayed exactly where it was before.... When I turn the car off the needle drops to zero and when I start the car again it only went up to where it was before (just above empty). And my gas light it still on. Any ideas?? |
Originally Posted by ek9max
(Post 3488264)
(Post 3488264)
The sending unit is a part that has a long and troubled history. As posted above, it's also not accurate on the lower end of the gauge. You need to fill up the tank to at least 3/4 to get it to start giving you the right reading. Of course that assumes the sending unit is still working properly. I had 3 of them go bad on my old 996.
One very easy way to break them is to leave the car running or leave the gauge powered while filling up. ALWAYS shut off your car while fueling! |
That does make sense. I probably didn't put enough in to have it register on the gauge. I didn't want to fill it up as the gas won't be used for a month anyways.
That is a really dumb thing for porsche to do.... Oh well! |
Fill up to the max and it will work again. I remember first time it happened to me, I went back to petrol station and accused them of cheating! Ha ha ha!
Originally Posted by teflon_jones
(Post 3488567)
i did this last week. filled a cpl gals, with no visual register of the added fuel to the gauge. on the way to refill, the gauge flatlined and the digital estimate of how much fuel went from a few miles to --------- .
not what you want to see in the middle of a ten mile canyon. |
The problem with the sensor (and the tank) is there is a hump in the tank. Basically two compartments of the tank. The sensor is in the upper portion of the tank and therefore does not read the fuel in the lower portion. As already said, the computer estimates what is there based on fuel consumption.
Just found out my 07 GT3 RS has the same issue. Filled it all the way until it overflowed , gauge is still at 1/4 and it went from 80 miles remaining to 50 miles today after a short drive. The tank is absolutely full.
Time me to have it checked out ? |
