need help with setting # on PSS9's
I have the FVD version of the PSS9... I forgot if the higher the number the firmer the shock or the lower the number.. anyone here have the answer for me? Thanks in advance
Higher number is softer and lower is firmer. I run mine on 4 front and 3 rear and it rides pretty decent. Used to run 3f 2r for a while but is not quite as compliant.
thank you silver
4 and 4 here and no longer have the front end bobbing that I had with higher number in front. I found tires played a HUGE part in the mix as well. Replaced my worn Cups with new Hankook V12s and it really made for a smooth ride- not too bad at track either. With the Cups it felt like the back end skipped sideways over any road cracks.
| All times are GMT -6. The time now is 03:37 AM. |
