X50 with UMW tune, can the stock clutch handle it?
Old Apr 12, 2012 | 07:17 PM
Darth GF's Avatar
Darth GF is infamous around these parts
Not here to debate tune or tuners...
Just wondering if anyone here has a stock clutch and a UMW tune? I'm curious to know if I should plan for a clutch...
Old Apr 12, 2012 | 07:45 PM
viprklr's Avatar
viprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond repute
Will last about a month. I was easy with my car & got about 30 days before the clutch started slipping.
Old Apr 12, 2012 | 08:41 PM
Darth GF's Avatar
One month sucks...
I bet there are hundreds of threads on clutches, but what is the usual go to clutch kit if/when I need a new one?
Old Apr 12, 2012 | 09:58 PM
VAGscum's Avatar
Originally Posted by Darth GF
One month sucks...
Clutchmasters fibertough and the Sachs kit Kevin @UMW sells.
Old Apr 12, 2012 | 10:21 PM
Turbo Fanatic's Avatar
Stock clutch should be fine if it's in good shape...
Old Apr 13, 2012 | 01:45 AM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
I have an epl stage 2 flash and exhaust for well over a year now with a stock clutch. no problems, and there definetly is some spirit driving in there as well. Plus it's my daily driver.
Old Apr 13, 2012 | 02:02 AM
TekNiC3's Avatar
TekNiC3 is infamous around these partsTekNiC3 is infamous around these parts
I have the EPL flash for about 7k miles on the stock clutch and it still feels fine.
Old Apr 13, 2012 | 04:37 AM
deckman's Avatar
UMW tune here with stock clutch for 6 months. No issues.
Old Apr 13, 2012 | 05:43 AM
ard's Avatar
ard
UMW tune, 91 and 100 octane; stock clutch, couple of years
Depends on how stupid you drive...pretty simple actually. I could kill it if I wanted.
Old Apr 13, 2012 | 09:33 AM
kato1453's Avatar
kato1453 has a spectacular aura aboutkato1453 has a spectacular aura about
1000 miles on Kevin's hybrid turbos and no clutch issues. OEM clutch
Old Apr 13, 2012 | 11:01 AM
Simi_996's Avatar
Simi_996 is infamous around these partsSimi_996 is infamous around these parts
If you ask UMW, they will say no.
However, the stock clutch is supposed to hold 600 ft-lb of torque, so in theory, if your clutch is in good shape, you should be OK.
I have a new stock clutch and an EPL tune and so far so good. However, I do sometimes feel like it does slip a little if I shift fast and hard.
If I had the budget, I would've upgraded my clutch, flywheel, and the slave.
Old Apr 13, 2012 | 04:08 PM
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
The stock clutch on my X50 wasn't strong enough for the car. With a tune, definitely not strong enough!
Vivid sells a Clutchmasters kit with a modded pressure plate that I finally decided on after EXTENSIVE research. They also offer a LWFW that's heavier than the Sachs version so it doesn't chatter as much.
Old Apr 13, 2012 | 06:02 PM
johnspeed's Avatar
Hi,I have had 2 clutchmasters set-ups in my car and now I went with Sachs Performance clutch set-up from Germany, its the best modulation and feel that I ever had ...Very Happy,just have to see how long it lasts with my power level ,which is a little more then what you have now..
Old Apr 13, 2012 | 07:42 PM
Fadi's Avatar
Fadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond repute
No way, mine held for less than a month. Depends in no of hard pulls not on miles !!
Old Apr 14, 2012 | 02:09 AM
Carbon's Avatar
Carbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond repute
When I spoke with Kevin on the phone he told me that it's a very real possibility. He said he even sees some K16 flashed cars roasting clutches.
I'm holding off on flash + exhaust for now until I know I also want to pay for a new clutch and labor on top of it.
