Hydraulic car lift and lifting options
Old 04-21-2012, 06:18 PM
tphss's Avatar
tphss is a glorious beacon of lighttphss is a glorious beacon of lighttphss is a glorious beacon of lighttphss is a glorious beacon of lighttphss is a glorious beacon of light
I'm thinking of buying a hydraulic lift, something movable and not mounted into the floor. If not, then to have a comfortable setup that lifts the car more than a foot of the ground.
This one looks nice in the video they have (under the picture "Product Video"):
http://www.gregsmithequipment.com/At...e-Scissor-Lift
Please post pictures of how to lift/jack your car to work on it.
Old 04-21-2012, 07:03 PM
Slider's Avatar
Wow, the price on that looks great. Might not be so easy to move around though at over 1000 lbs, you won't be standing that up against the wall when you're not using it.
Old 04-21-2012, 07:27 PM
tphss's Avatar
It does look really good for the price.
I saw it's still extremely heavy, but as long as I can park a car over it when it's flat it can stay there.
Old 04-22-2012, 06:07 AM
ttboost's Avatar
I just bought and installed a Greg Smith lift. The OH-10x. With some help, got it up and running in about 6hrs. I had the celing height, so I got the tallest widest lift they had. You'll save some loot if you can go get it yourself at one of their "local" warehouses, if you are close enough. I only had to drive 2hrs up and back, so no brainer for me. Works good, but is still kinda slow and jerky on the way down, but gets the job done. Cheap too...
Old 04-22-2012, 02:31 PM
heeltoe914's Avatar
heeltoe914 has a spectacular aura aboutheeltoe914 has a spectacular aura aboutheeltoe914 has a spectacular aura about
I personally love my scissors lift, its a great investment for a standard 9 foot garage ceiling height. I use mine as a back up when I have projects on the two post lift up front. It was truly shocking to me how much I can do on this lift. As you can see I pull 914 and 911 motors on it with no problem I think mine is the 72 inch high one. My scissors lift is more stable than having a car on my two post lift. I think it has to do with the base being directly under the car. You had asked or mention moving it around mine was designed just for that as I think most are, it has little dolly thing that you pull up on and that allows you to drag it wherever you like smooth surface works best. Another great thing is that for lowered cars I made the ramp that you can see under the car in the pictures. I can very easily drive my slammed NSX or turbo right up to it and lift. But it also works as a normal daily driver parking spot if needed. no need to move the lift around after working on your car.
Old 04-22-2012, 02:46 PM
heeltoe914's Avatar
better pix
Old 04-22-2012, 03:06 PM
heeltoe914's Avatar
Old 04-22-2012, 04:59 PM
tphss's Avatar
That looks actually really good heeltoe thanks for the pics. Do you need the ramps in order to go on the scissor lift or you can just drive over it, set the jack locations and lift it up?
What brand scissor lift do you have? That height looks like you can't stand underneath (nor can you lay down on the floor). Do you sit on something under the car and work on it?
Old 04-25-2012, 12:45 AM
Danyol's Avatar
Danyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant future
I have a scissor lift very similar to this one, labelled Snap On but made by Wheeltronic. Many of these are very similar, I have to use a couple of 2x12s to clear the lift.
Works great for me.
COBB Tuning
01-29-2022 09:42 AM
PorscheEnthusiast
11-13-2015 02:23 PM
gulf gt
08-27-2015 10:27 AM
WheelB
American Muscle
08-24-2015 08:42 AM
silver86
Cayenne 958
08-21-2015 03:08 PM
Quick Reply: Hydraulic car lift and lifting options
