View Poll Results: My coolant pipes are:
Original, have not failed.
132
68.75%
Pinned/welded preventatively.
39
20.31%
Pinned/welded due to a failure
10.94%
Voters: 192. You may not vote on this poll
Have you welded/pinned your coolant lines?
Old 06-20-2012, 12:20 AM
bushman66's Avatar
bushman66 is on a distinguished road
2001 48000 miles. Unknown Flash. Original.
Old 06-20-2012, 02:19 AM
Carbon's Avatar
Carbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond repute
2004 Stock X50 with around 19,500 miles and original coolant lines.
Old 06-20-2012, 04:56 AM
landjet's Avatar
2002, 30,000 miles, modded for track, welded pipes as preventive measure.
Old 06-20-2012, 05:23 AM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
2003 modded,welded pipes as preventive measure.
Old 06-20-2012, 05:26 AM
thomapa1's Avatar
thomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of light
-Year: 2003
-Mileage on car: 64,000
-Stock or modified? Modified
-Are your lines pinned, welded, or original? Welded, but only the 3 most common failure points
-If pinned or welded, was it preventative or due to failure? Preventative, after my shop had observed degradation of the glued fittings
-If you had a failure, describe the situation (track, spirited, commute, around town ect...):No Failure
Old 06-20-2012, 05:52 AM
AdrianM5's Avatar
AdrianM5 is a name known to allAdrianM5 is a name known to allAdrianM5 is a name known to allAdrianM5 is a name known to allAdrianM5 is a name known to allAdrianM5 is a name known to all
2003
24,400 miles
Modified
Original
Old 06-20-2012, 06:30 AM
cburke996's Avatar
cburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of light
Thanks for the info guys. For those who had them welded, how strong was glue at that time? Was there significant degradation? (Thomapa1 noted there was)
Old 06-20-2012, 08:02 AM
raineycd's Avatar
-Year: 2002
-Mileage on car: 55,000
-Are your lines pinned, welded, or original? pinned
-If pinned or welded, was it preventative or due to failure? failure
-If you had a failure, describe the situation (track, spirited, commute, around town ect...): spirited
Old 06-20-2012, 09:12 AM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
For those who have not yet fixed this issue, you will be left stranded somewhere guaranteed.
Old 06-20-2012, 09:51 AM
Lennon31987's Avatar
Lennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond repute
-Year: 2003
-Mileage on car: 13,000
-Are your lines pinned, welded, or original? Original
Modded with turbos, injectors, IC's, etc......
Old 06-20-2012, 10:13 AM
raineycd's Avatar
Originally Posted by Tony@epl
^^^ Agreed. Would also like to add, for those that are "pinned", I would consider that a temporary fix. If when your engine is out, have the pipes welded.
If you have pinning done well, I think it will easily be a 10-15 year fix! If that is temporary, then I am ok with that! By then, the engine will be out for something else anyway and things can be checked, etc.
Either way, it is a must do for these cars at this point. Just glad I was in town when it happened. It was only list of things to do this year, but failure beat me to it!
Old 06-20-2012, 11:08 AM
raineycd's Avatar
Tell that to the guys in my area (not pinned here) that are pulling their motors a 2nd time.... They will leak, its not a matter of if, its when.
How long did they last and did the installer take extra measures?
My tech pinned with o-ring washer, locktite, and expoxy on top. Then epoxyed around the pipe as well.
Like I said, if it is done right, I don't see why it would not be a 10 year fix. I have full confidence in my repair and if they do leak, they have a lot to get through first!
Then you have the guys who have to pull their engine a 2nd time for a pin-hole leak in a weld. I think technique and care is just as important as method.
Old 06-20-2012, 11:18 AM
raineycd's Avatar
Heat and vibration are the 2 killers of any of the additional expoys/sealants that shops are using. One car we saw didn't make it 5-10 miles without leaks (again, not one we did here).
Anyway, sounds like your shop has a handle on it. We've just made the decision around here (recently) that pinning isnt the proper solution.
If you have a good welder that knows what he is doing, then welding is the way to go. I did pinning for many reasons, but those are variables that others may not have to deal with...
Old 06-20-2012, 11:20 AM
agreed. pinning will simply stop the fitting from popping out. it will not stop the glue from drying up and letting coolant leak by the fitting. i dont see why people would not weld if motor is out of the car. for those worried about pin sized leaks, you fill the motor with water and pressurize i to test it before reinstalling into the car. do it once and do it right.
#TeamAIM
Kapoosh1's Avatar
Kapoosh1 has a spectacular aura aboutKapoosh1 has a spectacular aura aboutKapoosh1 has a spectacular aura about
02 X50 60K miles
Flash/exhaust
Still all original
Quick Reply: Have you welded/pinned your coolant lines?
