View Poll Results: My coolant pipes are:
Original, have not failed.
132
68.75%
Pinned/welded preventatively.
39
20.31%
Pinned/welded due to a failure
10.94%
Voters: 192. You may not vote on this poll
Have you welded/pinned your coolant lines?
Old Mar 24, 2016 | 09:19 AM
  #76
SeattleTurbo's Avatar
SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !
-Year: 2001
-Mileage on car: ~82000
-Stock or modified? Virtually stock; no performance improving mods, but have used upgraded OEM parts to replace originals due to failures/maintenance (ie- 710N diverters, 997 coils, etc)
-Are your lines pinned, welded, or original? Pinned
-If pinned or welded, was it preventative or due to failure? Fitting failed under normal driving conditions on freeway within 100 miles after first track day.
Old Mar 24, 2016 | 01:30 PM
  #77
viprklr's Avatar
viprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond repute
Coolant lines
I posted earlier that I blew a top coolant line while out on the track at Indy. Thankfully no injuries/damage to anyone. I did have the coolant lines pinned. As an aside, one of my best friends has several Porsche vehicles including a 2006 Porsche Cayenne Turbo S that he had the coolant lines pinned 2 years ago. He is part of a class action suit against Porsche & received documentation that he is going to receive some type of compensation for the repair (completed at a Porsche dealership). Is there any other info out regarding our cars (GT3, GT2 or TT).
I forgot to mention that my 2003 996TT has 20,8xx miles on it.
Old Mar 25, 2016 | 10:37 AM
  #78
dashjeff's Avatar
dashjeff is infamous around these parts
-Year: 2004
-Mileage on car: 82k
-Stock or modified? Bone stock
-Are your lines pinned, welded, or original? TBD, planning to weld. I experienced the failure 100 miles after purchasing the car (on the way home)
-If pinned or welded, was it preventative or due to failure? Due to failure.
Old Mar 25, 2016 | 11:56 AM
  #79
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
-Year: 2001
-Mileage on car: 65,000
-Stock or modified? Modified
-Are your lines pinned, welded, or original? Welded
-If pinned or welded, was it preventative or due to failure? Preventative
Old Mar 31, 2016 | 05:04 PM
  #80
MotoJB's Avatar
MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !
2001 996 TT with 44k miles.
Simply doing mine "while we're in there". Pulling it all for a transmission job so might as well do it.
Pinning mine because the shop I'm using doesn't weld.
Old Apr 1, 2016 | 12:07 AM
  #81
FI_FTW's Avatar
FI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond repute
-Year: 2002
-Mileage on car: 73,xxx
-Stock or modified? Stock (except for exhaust)
-Are your lines pinned, welded, or original? Original. Plan on welding; probably a 2017 project.
Old Apr 5, 2016 | 11:58 PM
  #82
996TTBOOST's Avatar
996TTBOOST is infamous around these parts
2001 996 TT
40k
Stock
Original will pin/weld if when the motor needs to come out
Old Apr 6, 2016 | 11:10 AM
  #83
Samajam's Avatar
Samajam is infamous around these parts
2003 tt
76k kms
modified
preventative pinning last weekend as part of track prep
Old Apr 7, 2016 | 04:29 PM
  #84
necostanzo's Avatar
necostanzo is infamous around these parts
2003 TT
22K miles
Original
Pinned for preventative measures during MX
never failed
Old Apr 8, 2016 | 10:00 PM
  #85
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
Luckily Mine failed when i was pulling out the engine to change a tiny o ring that had failed on the top.
Had approx 120k miles on the clock.
Welded in some torque solutions fittings. If you havent done and u drive ur car as it was intended id be seriously thinking about getting it done or at the very least having the parts on stand by
Old Apr 8, 2016 | 11:04 PM
  #86
JimTT's Avatar
JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !
Hey Tim,
Haven't done mine yet.
Good to see you back on here, get well buddy.
Cheers
Jim
Old Apr 9, 2016 | 01:12 AM
  #87
timccloud's Avatar
Originally Posted by JimTT
Hey Tim,
Cheers
Jim
Thanks Jimbo ur a true gentlemen.
Old Apr 9, 2016 | 08:07 AM
  #88
jpflip's Avatar
2002.
70,000 kilometers (43,000 miles).
Welded (before flash + exhaust).
Fitting got loose on the water pump housing and start leaking.
Old Apr 13, 2016 | 03:05 PM
  #89
taylorcar's Avatar
taylorcar is infamous around these parts
How can I tell?
I have a 90,000mile 2002 996TT. I bought it recently, and probably didn't do quite enough research on common issues for the model prior to purchasing (got to the "it doesn't have the IMS issue" and moved on).
The vehicle had a number of owners and I don't have totally complete records. Is there an easy way to tell if the lines have been pinned/welded? Are any of the junctions easily visible by just opening the engine bay? Any suggestions as the easiest one to look for?
Car is stock other than lowering springs right now. Speedtech 3" just shipped. Tune shortly after that is planned.
Old Apr 14, 2016 | 06:04 AM
  #90
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
The fitting next to the coolant hose may be the easiest to see. Here is my engine after I had pinned the coolant fittings. You can see the head of the allen head screw in the circle. Basically you should see a screw or weld in this area.
Later, Steve
