-   996 Turbo / GT2 (https://www.6speedonline.com/forums/996-turbo-gt2-2/)
-   -   Battery Help Car won't Start! (https://www.6speedonline.com/forums/996-turbo-gt2/283589-battery-help-car-wont-start.html)
602996TT Aug 9, 2012 01:48 PM
I just changed my battery with an aftermarket one from Battery Plus I messed up big time and put it in backwards (I have changed 100's of battery's and can't believe my stupidity:mad:) After I realized what I did I hooked it back the right way and now it won't start or turn-over all the lights go completely dim after trying to start. My question is did I fry my ECU or RELAY or FUSES if so where do I start:confused: Please any info will be much appreciated I am going crazy thinking I fried my ECU??
03 996tt Aug 9, 2012 02:22 PM
Do a search as its happened to others with varying results and costs to repair. My friend did the same on his Magnum srt8 and $4500 later and, a new main wire harness, the car was almost perfect. Good luck
Hams996TT Aug 9, 2012 02:37 PM
Dang! Hopefully your fuses and breakers saved your car. If not... Man really sorry.... Definitely need to start checking every fuse/breaker over.
602996TT Aug 9, 2012 03:42 PM
Thanks I hope it's something simple I called my mechanic friend and he said most likely a fuse or relay dosent seem to think it's a fried ECU. I am more pissed off at myself for doing such a stupid mistake :mad:
602996TT Aug 9, 2012 03:43 PM
Thanks I hope so too I checked all the 40amp fuses so far no luck!
602996TT Aug 9, 2012 10:31 PM
Ok after reading a bunch of post today I figured out I blew my fuse in my radio so I replaced it with a 10amp fuse and car started right up :) but Now I have a warning light (Warning battery/generator) the manual says if you see this light to "Stop in a safe place and switch the engine off. Do not continue driving. have the fault remedied at an authorized Porsche Dealer" So what gives do I have to clear this light and hope everything electrical is ok or maybe my alternator could have an issue now?
03 996tt Aug 10, 2012 09:03 AM
It may be as simple as the voltage regulator went bad. Do a search as they are inexpensive and easy to replace.
wross996TT Aug 10, 2012 11:50 AM
you need to have the fault code read.
