View Poll Results: How many have replaced N75 valve in 996tt/GT2
2001 996tt/gt2 REPLACED
20.00%
2002 996tt/GT2 REPLACED
10.00%
2003 996tt/GT2 REPLACED
3.33%
2004-5 996TT/GT2 REPLACED
0%
Never Replaced
43.33%
What is N75 ?
23.33%
Voters: 30. You may not vote on this poll
Poll: How many have replaced N75 valve?
usually the problem is in the hoses connected to the N75 not the unit itself and by changing the unit you are also fixing the hose leaks... just an observation...
2001 996TT 3.6L and stock ECU
Hmmm, interesting. when I removed my y-pipe, I did not even think of removing the lines going to the N75, that would make the procedure a lot tougher.
The N75 valve is very cheap for a porsche product
I also now have a spare N75 ready to go in case I need it.
I checked all my hoses on mine before changing and everything was on tight and saw no splits or cracks in them. The car would boost 1.2-1.3 before now it boosts 1.3-1.4 on same tune after changing it out. I have a feeling it may have been failing I while back as the car was always a hair short of the desired requested boost level on my old FVD flash.
boost leak test is at the Y pipe... ... it will find everything...
OR if you have durametric you can log the n75 see if it works... simple..
Do you have a schematic diagram to show the N75 lines and hoses direction ?
TIA
Was for Markski but may be I can help...on the pictures you will found the location in the system, the valve itself (996-605-155-00) and the valve location in the engine compartment....
Agreed! it's not the n75 its the hoses connecting to it.
I appreciate this.
I go and check it
10-06-2015 03:43 PM
Ferrari
08-24-2015 04:35 PM
