Can a bad accumulator cause seeping of fluid at the front Clutch Fluid Reservoir?
Subscribe
Oct 23, 2012 | 05:38 PM
Or is it only the slave cyl failure that does this? I did a search yesterday and found this post (see post #9) which made me order the accumulator.
https://www.6speedonline.com/forums/...ring-pump.html
But then today I read that if you have leaking at the front reservoir it is the slave and not the accumulator.
I have the following symptoms"
1- hard clutch pedal on start up
2- When I press down the clutch to start the car is goes down further by an inch when the car starts
3- Clutch pedal is inconsistant when driving (sometimes easy sometimes hard to press)
4- Sweating fluid out of the cap at the front reservoir
So can this all be from a bad pressure accumulator or does the fluid at the front mean a bad slave for sure?
Thanks!
Jason
Reply
Oct 23, 2012 | 07:32 PM
yes, bad for sure. replace both slave/accumulator for stock setup and assisted "feel" or go to the gt2 mod conversion which though possibly costlier and possibly more labor intensive upfront is the preferred method of eliminating this annoying and frequent issue. at least you'll never have an accumulator fail again. i've gone through a few accumulators myself. slaves, less so.. but yours sounds like toast.
looks like a big day for accumulator issues on the 6 https://www.6speedonline.com/forums/...r-problem.html
Reply
Oct 23, 2012 | 07:39 PM
Damn it. That's what I thought. Well I already orderd the accumulator so I iwll just go ahead and order the slave cyl too. Thanks for your input!
Reply
Oct 23, 2012 | 07:53 PM
Be careful cleaning up the Pentosin - it's pretty corrosive.
Reply
Oct 24, 2012 | 07:03 AM
Quote: Damn it. That's what I thought. Well I already orderd the accumulator so I iwll just go ahead and order the slave cyl too. Thanks for your input!
no problem.. replace both simultaneously, and think of it as your "initiation" into the club i would've done the gt2 mod by now myself.. but i actually like the stock setup ( ducking ).. when it works properly
Reply
Oct 24, 2012 | 07:17 AM
Quote: no problem.. replace both simultaneously, and think of it as your "initiation" into the club i would've done the gt2 mod by now myself.. but i actually like the stock setup ( ducking ).. when it works properly
Ya I guess I cant complain seeing as this is the only problem I have had since I bought the car early this summer (knock on wood).
In fact the fluid was always present at the front reservoir and the clutch was always hard on start up right from day one so it was like this when I bought it. It has just developed a bad leak at the accumulator so I am only looking into now as I never knew it was an actual problem before. (thought the reservoir was over full and that these cars had a hard clutch on start-up).
Reply
Subscribe
