Nitto Invo Tires
Well guys apparently nobody in the northern side of this continent has NITTO INVO tires 315/25/R19. Everybody is out of stock and the backorder could be for 2 months. If anybody knows well to find it, please let me know. :cool:
Switch to Toyo's or make the switch to the 245/35/19 and 305/30/19 combo
I made the switch from 315 to 305, I prefer the 305, the added sidewall makes a huge difference in the 30. Best of luck! |
Originally Posted by dhahlen
(Post 3681514)
Originally Posted by Hector-PRAC
(Post 3681662)
Thanks for the info...my biggest problem is that my wheels are 19X12 and a 305 will be too stretched...if I go with 325/30 it will rub with the inner plastic. The other thing is that I only need the rear ones because the front tires are barely new.... if I have not choice I think I may had to buy all four from other brand. This will be for the X50 which is stock in all aspects.
The 305/30/19s won't match up with your fronts if you're AWD however.... |
Originally Posted by pwdrhound
(Post 3681673)
They won't be stretched. Porsche OEM wheels and tires on the 997.1 GT3 are 19x12 with N spec 305/30/19 tires. If the factory does it so can you......
(Post 3681683)
I have 235/35/19 in the fronts and I'm running awd would the 305 works?
