Using torque wrench when tightening lug nuts
Old 11-02-2012, 11:54 AM
polar3's Avatar
polar3 will become famous soon enoughpolar3 will become famous soon enough
Just curious how many lbs of pressure I should set the torque wrench to when tightening up wheel nuts.
Old 11-02-2012, 12:29 PM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
I do about 92
Old 11-02-2012, 01:39 PM
uschoice's Avatar
uschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant future
Do it in stages too.
Old 11-02-2012, 01:58 PM
jpflip's Avatar
96 ft/lbs as per repair manual....
Old 11-02-2012, 02:05 PM
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
I first stage torque to 65ftlbs. Then torque to 100ftlbs. I am aware that the factory spec is 96 but with most torque wrenches tolerance at four percent I want to be sure they are at least 96.
Old 11-02-2012, 06:23 PM
RennFab's Avatar
RennFab is a glorious beacon of lightRennFab is a glorious beacon of lightRennFab is a glorious beacon of lightRennFab is a glorious beacon of lightRennFab is a glorious beacon of light
Basic torque wrench proceedures:
-Final torque of 96ftlbs
-Always ensure wheel and lugs are seated before torquing. Suggested two step torque recommended, but best to do initial torque of about 50% of final torque(45-60 ftlbs)
-Most important, ALWAYS complete final torque in one swing. This is because if you make a swing and don't reach the final torque, the breakaway torque to get the stud/nut moving again can exceed the final torque setting on the wrench and the head will click off as soon as you try to torque to the final spec again. This leads to an under torqued fastener. If this happens, back the lug off and torque again from the start.
Old 11-02-2012, 11:12 PM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
Use a tire iron and tighten it to " about that much"
Old 11-03-2012, 06:08 AM
32krazy!'s Avatar
german torque. "gutentight!" lol. my shop told me 96 ft/lbs in 2 stages
Old 11-03-2012, 10:13 AM
Snowczar's Avatar
Snowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to behold
When Tourquing it's important to go back and forth across the wheel rather than tightening sequentially around the wheel.
John in Vancouver
Staff@WORLD
02-08-2016 09:22 AM
su_maverick
09-08-2015 11:12 AM
porsche42
09-04-2015 08:21 AM
DLF
Cayenne Turbo
09-03-2015 01:36 PM
zuman
09-03-2015 08:27 AM
Quick Reply: Using torque wrench when tightening lug nuts
