Gt2 Small Boost Leak
Hello!
I was wondering if it is possible that my gt2 has a small boost leak. I haven't got any CEL lights about low pressure, but my car doesn't hit the bar I thought it was supposed to. I live in the seattle area which is always around the 50s(f) in the winter. On WOT my gt2 makes it to .8 bar at the end of the pull (5-6k rpm) but usually sits around .7bar. Occationally I get a spike to .9bar. Is this a normal boost pressure? Thanks Edit: This is my car BTW: https://www.6speedonline.com/forums/...re-wheels.html |
.8 or peaks of .9 was all i ever saw on my stock 24's. sounds about right, absent other issues.
When my X-50 car was stock, it was most of the time seeing .8 and when cold .9
Would the dash read a lower bar under WOT if there was a leak?
Originally Posted by TabooPc
(Post 3686397)
your fine stop worrying... if the car holds .6 bar then you should consider looking into it...
your fine stop worrying... if the car holds .6 bar then you should consider looking into it... I've actually been talking to you through email about doing your turbo turbine upgrade.. ;) |
:0 no worried enjoy the car...
You have a problem... Its called small turbo syndrome... You can live with it or address it and begin to live your life a little more on the wild side.. At least you took the step to identify the problem.
You have a problem... Its called small turbo syndrome... You can live with it or address it and begin to live your life a little more on the wild side.. At least you took the step to identify the problem. I think my goal is about 600 crank HP to start out.. Probably will just start out with a K24/18g billet upgrade running off a 5bar fpr and then go from there. Doin' it in steps. ;) |
as i remember my stock gt2 boost was at 1,0 bar at high load/ 0,9 all the time
(Post 3687104)
Well from what I've read you have a problem aswell... Its called huge turbo syndrome. I'm hopeing to get a little bit of both.
Originally Posted by Tim941NYC
(Post 3687295)
hilarioushilarious Johnspeed may be selling his 18g's:eek:
Are they billet? |
Tim from NYC - you took the words right out of my mouth - small turbo syndrome! We all started there.
add some injectors, and good 3 inch exhaust, dv, and a proto tune, you'll be much happier. for now;)
