Sooo... this means my radiator is leaking?
Correct. I came out to the garage to find exactly the same situation as pictured in the original post. Left=Drivers side. For some strange reason, even though they are mirror images of each other, the Right/Passenger side radiator is more $ from every vendor.
Cheers
Mikey
Cheers
Mikey
You guys will see when you start pulling it all apart.
Two tabs on one end of the hose where it attaches to the rad and traditional hose clamp where it attaches to the hard line that runs to the back.
Let's just say I'm glad I didn't pre order a new rad.
Regardless it's an easy fix.
deckman
I am trying to PM you but for some reason I cannot. Please email me if you don't mind. I have a question for you.
lhvanroo@gmail.com
Kind regards
Luke
lhvanroo@gmail.com
Kind regards
Luke
Last summer after a fast canyon run on a hot day I could smell coolant up front, never a drip on the floor though. It got to the point that after driving more than a few miles the smell was always there, like when my C2 developed a cracked reservoir. I asked a Porsche senior tech and long time personal friend about this and he said he could fix me up for less than $2k with new parts, coolant and labor. He also whispered Alumiseal to me, wink wink, nudge nudge, knowing I do most all my own work. So I'm out $6 and have not had this smell in about 6 months. My coolant level hasn't dropped an oz. either.
I can smell coolant but I have no coolant level drop in the reservoir. So I am leaving mine until I see a drop like yours. Also my Porsche tech tells me smelling coolant in turbos is normal. I am unsure if I buy this but it is strange that I have no coolant drop. Maybe smelling some vapour is normal?!
Damn, my right and left sides are both leaving drops on the floor. I noticed it when temps got real cold. I haven't driven the car in a few weeks until I can get this fixed. Glad this looks like its an easy fix although bleeding doesn't sound fun. Is it recommended to replace all 3 rads while in there?
Cheers
Mikey
I had one front fan pack out on me. Changed just the one. The other one working without losing a beat.
Anyone have bleed instructions, looked in the service manual and didn't see it. Same with bumper removal? I removed the left wheel/spash guard and I don't think I can get the rad out with out pulling the bumper. I get the whiff but no leaks, so I figure ill replace the rad for good measure. Thx.
Btw some good bleed info here after some searching...
http://forums.pelicanparts.com/porsc...nt-change.html
related ?
So there is a small coolant leak under the back driver's side of hte engine compartment. It's coming from somewhere higher up and driping along and down, haven't had chance to look further up yet. Here's the question. I had the car on a pressure test for like 6 hours, no drip. Car sits for a day or two not running = little puddle. This seems the opposite of what I would have expected! Any thoughts?
