Trying to collect parts for GT2 slave conversion, PITA
Old Dec 26, 2012 | 06:15 PM
pwdrhound's Avatar
Originally Posted by 32krazy!
like the op said i tried both sites and couldnt all the needed parts. was just wondering what the total would be.
GT2 Slave…996 116 237 90 $130
GT2 Master…996 243 171 06 $65
GT2 Assist spring (you definitely want this, trust me)…996 423 081 18 $55
Brake fluid cap…996 355 119 01 $5
GT2 Hose…996 423 377 90 $105
GT2 Clutch fork…997 116 086 90 $180
GT2/Tip PS reservoir (optional, you can just plug the lid)…997 314 920 50 $480
GT2 PS pump (optional, just remove the coupler from the turbo pump)…996 314 050 01 $400
Ok, so these are the prices I paid, give and take a few bucks. So that's a total of $1020 but the GT2 PS reservoir at $480 is a large part of that. At retail prices you'd be closer to $1350-$1400. I did not buy the GT2 PS pump as it's pretty easy to disassemble the TT pump and remove the coupler (do NOT skip this step!). Add about $800-$1000 for labor to drop, drill and tap the gearbox, remove all the unused hydraulic lines, and you're at about $2k+ or so to have the conversion done just like on the GT2. In the end it came out a bit cheaper because I recouped about $550 by selling my Turbo PS reservoir for $300 and also the Turbo slave/accumulator that was removed for $250. I sold both here on 6speed. Best time to do this is if you're having the clutch done or if your engine is coming out for any reason, to have the pipes welded for example. Hope that helps...
Old Dec 26, 2012 | 06:18 PM
32krazy!'s Avatar
Ok, so these are the prices I paid, give and take a few bucks. So that's a total of $1020 but the GT2 PS reservoir at $480 is a large part of that. At retail prices your'd be closer to $1350-$1400. I did not buy the GT2 PS pump as it's pretty easy to disassemble the TT pump and remove the coupler. Hope that helps...
awesome. thats exactly what i was looking for. thanx a bunch!
Old Dec 26, 2012 | 09:43 PM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
Do I need that clutch fork? How is it different than the TT? Thank you for the part numbers pwder very helpful.
Old Dec 26, 2012 | 09:56 PM
brnrdtns's Avatar
Those numbers check out except for the master Cyl, I have a different number 996-423-171-06-M33 on Pelican. I guess it is the same one that the boxter and C2/C4 use?
Old Dec 26, 2012 | 10:49 PM
pwdrhound's Avatar
Yes, 996 423 171 06 is the right number. I just fat fingered it in my post
Old Dec 26, 2012 | 10:52 PM
pwdrhound's Avatar
You need the GT2 clutch fork if you want to do the install without the bracket just like its done on the GT2 where the slave is mounted on the left side of the transmission. The GT2 fork is a mirror image of the TT fork.
Old Dec 27, 2012 | 12:50 PM
brnrdtns's Avatar
Ok, got everything ordered. That sucks that fork is pricey for something so simple.
Old Dec 28, 2012 | 01:50 PM
cburke996's Avatar
cburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of lightcburke996 is a glorious beacon of light
Where were you guys able to get a longer slave cyl hose made up at? I don't know who will do that around me.
Old Dec 28, 2012 | 02:04 PM
brnrdtns's Avatar
I'm going to try a large business near me that deals with all sorts of industrial hydraulic equipment. I've had them make me hoses for tractors that I have and I think they can do about anything. I'll just bring the parts with me and I'm sure they will have something that will work. It's just a hose after all.
Old Dec 28, 2012 | 09:44 PM
pwdrhound's Avatar
You only need a longer hose if you are using the bracket method. If you go the GT2 route than all you need is the stock GT2 hose. Evoms can probably just sell you the longer hose from one of their kits if you need one.
Old Dec 29, 2012 | 09:38 AM
VAGscum's Avatar
It is a brake hose. You might be able to source a stock brake hose that will work.
Old Dec 29, 2012 | 10:45 AM
flavorPacket's Avatar
flavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond repute
They refused to sell me just the hose when I asked. I ended up buying the GT2 hose and bringing it to a local hydraulic shop to extend it.
Old Jul 19, 2013 | 12:32 PM
XLR82XS's Avatar
Originally Posted by m3ntal
Leave the assist spring off....and do you REALLY need the cap?
Will this eliminate a very stiff pedal?
Old Jul 20, 2013 | 09:43 AM
The spring reduces the effort needed to depress the pedal.
SharkyShark20
Sep 19, 2015 09:54 PM
Murf4
New Member Introductions
Sep 3, 2015 10:10 AM
TrackOne
Aug 20, 2015 12:56 PM
Rumrunner
Charity Notices/Events
Aug 20, 2015 11:07 AM
