She's going under the knife tomorrow
She's going in tomorrow for K24/20, IC, 72lbs injectors, 4bar FPR, coolant pipe fix while we are in there and EPL flash tomorrow.
I'll be so stressed that I have to take a week in Maui to calm myself down before I come back and discharge her. Wish me luck ! |
Always stressful! Good luck with her. Keep us up to date.
Best of luck!
-Jorge |
You might want to upgrade the fuel lines from the front of the car to the fuel rail. That will help with fueling and in case you do the pumps later its a lot easier to do now when the motor is out.
- David |
Originally Posted by SSMugen
(Post 3776581)
- David Thanks |
Originally Posted by rxbike
(Post 3776598)
I will look into that
Thanks good luck! |
Nice mods. Who's doing the work?
Ipb-autosport in downtown Sacramento
Owner Ron Kain |
(Post 3776581)
- David |
Great news. I actually was going to look into doing this myself but heard from someone that it was pretty labor intensive.
Thanks!
Originally Posted by Ms4cd
(Post 3776888)
I have done with engine in. Not a big deal.
Very interested in the power output of this set up.
Subscribed! Thanks Bobby Ali ba |
Why not a3071 or a3076 ?? You will get more power ..
Whats the HP target for your project ? Good luck .. Hope you enjoy it :) |
Originally Posted by ysfg35
(Post 3777171)
Curious as to what steered you in the 24/20 direction? |
(Post 3777171)
Whats the HP target for your project ? Good luck .. Hope you enjoy it :) 24/20's will get you above the 700whp mark. I have not seen many 3071's or 3076's that go past the 700 whp mark. |
Originally Posted by PAULIEWALNUTS
(Post 3777259)
How much whp would you go on a stock block?
24/20's will get you above the 700whp mark. I have not seen many 3071's or 3076's that go past the 700 whp mark. Not sure if I'll be going beyond this set up. ... Famous last words i got the turbos used from another member for a phenomenal deal so it was an easy no brainer. These turbos were used for only ~5k miles in its current state before he upgraded so I was the benefactor. Thanks to Sid, I'll smile a little more. Will add that with the current AR Design exhaust set up, I have the option of going catless with just dropping the cats via the band clamps and inserting the bypass pipes. Very nice design and not requiring a lot of work to do. I would say 30 mins to do both. Wanted to give them a shout out for working with me and other members on this forum on their exhaust setup. Looking ahead at PSS10 in the near future. May 2-2 months from now. |
| All times are GMT -6. The time now is 02:06 PM. |
