Foam blowing from vents and rattle
#63
I just thought I would follow up on this repair. Now that it is HOT and MUGGY out, the new HVAC unit is awesome! When I first got the car, I was disappointed with the performance of the A/C operation on hot days. I just attributed it to being black and figured it must be a "Porsche" thing...lol I had checked the freon and everything checked out good. Now that the blend doors aren't "blending" the hot air with the cold air, the car cools down very quickly and not having the foam bits blowing on my wife's clothes is a plus! I have to admit, it is a tedious job. Anyone with mechanical skill and patience (which I have very little patience, but I twist wrenches since a young child) can do this task. Take lots of pictures and good luck!
#65
Hi Vantaredoc! Thanks for taking the time to document your experience with this. If you don't mind, I have a few questions please.
First, if you had your replacement part in hand, how long would it have taken from start to finish to swap it out, if there were no interruptions?
Second, in an earlier message, you mentioned that this also "cured" a noise that you were getting from that area when going over bumps. Do you think it was those flaps bouncing and the noise was the "plastic to plastic" contact? ( I have a similar noise, and haven't been able to find where it's coming from, but your comment about this has me thinking it could be the culprit)
Third, based on your experience, and the possibility of this happening again, is there another fabric we could use that would be better suited? Maybe a plastic screen or mesh?
Obviously mine being 16 years old and having spent its life in the Houston heat, mine appears to be suffering from the same ailments.
Thanks again for your write up, it is very much appreciated!
Greg
#66
Greg
Greg
First, Probably 2-3 days
Second, It is a metal to plastic rattle and yes it cured the main one I had. The worst of the rattles were the trac bars!
Third, Im not sure about this one. The flapper doors are sheet metal with very large circular holes and covered with a foam tape. So Mesh would be out of the question as it needs to not allow to pass through it.
It was a pain, but the gain has been worth it! This summer here in Fl was very hot and the a/c performed awesome!
detailersdomain
Detailing
01-11-2016 09:35 PM
detailersdomain
NY Tri State
09-29-2015 08:35 AM
detailersdomain
BMW //M
09-29-2015 08:34 AM
