anyone taken the rear alignment to 0?
#32
Originally Posted by brnrdtns
Should I get adjustable thrust bushings? How valuable is caster adjustment?
#34
How much do sway bars help? I've read about some who just changed the rear and not the front. What are your thoughts on that?
#35
I'm on PSS10's and aggressively low. Tires are lasting me about 12k on the street. Would just solid thrust arm bushings go a ways to address toe control without the others? I suspect it's the big donut in the TA that degrades the most?
#36
Adjustable toe links will make the best improvement if significantly lowered. Thrust arm bushing are relatively cheap in the big picture.
#37
Toe links for $200, I wonder if these are any good. https://thmotorsports.com/i-2000254....JHnhoCgQ3w_wcB
#38
Ok I think I am going with Torque Solution. They look to be good quality for a pretty good price. $449 for the toe arms and $225 for the thrust bushings. The bushings are adjustable for both front and rear. Will it be simple enough to just put them in at the center setting and call it good? http://www.evoms.com/mobile/Product.aspx?id=38186
#39
#41
Did you pair this with solid TA bushings, or just the toe link?
#42
Ordered the Torque Solution arms and bushings. I will take a look at all the other bushings and will replace as needed. I know how we all hate Vivid for screwing over that guy with the 4.0 that had damaged liners, but they were significantly cheaper than everyone else. Free shipping with code SHIPTHIS. $572.90 to my door.
#44
I have their rear sway links and tranny mount bushings. They were not particularly bad on ship time IIRC.
