Starting car for first time since 18g injector swap, what to watch for to be safe?
Old Jun 12, 2013 | 10:19 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
I'm starting my car up probably tonight and am wondering if I should hook up my durametric or my D guage and watch the AFR's to see if there is a problem. How will I know if an injector isn't working or if the tune didn't work? What are the AFR numbers exactly that I should be watching out for? Thanks.
Old Jun 12, 2013 | 11:20 AM
raineycd's Avatar
What all was swapped? FPR? Tune?
Old Jun 12, 2013 | 11:30 AM
brnrdtns's Avatar
k24/18g's
60lb injectors, stock FPR
tune
exhaust
inlet pipes
coolant pipes welded
Old Jun 12, 2013 | 11:41 AM
raineycd's Avatar
Cool! Starting up/idle should be fine as long as no leaks. Getting into boost I would work it up and log everything. Work with your tuner to be sure everything is going as planned.
Do a boost leak check prior as well. Check my sig for Pressure Test DIY
Old Jun 12, 2013 | 12:37 PM
dhahlen's Avatar
dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !
Fire. Always good to watch for fire.
Going to be a different animal!
Old Jun 12, 2013 | 01:56 PM
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
boost test first as others have mentioned. Use common sense and listen for anything unusual. Let it run for a minute or two and turn off and pull the plugs on the turbo drip tanks to make sure they are getting oil.
Old Jun 12, 2013 | 02:09 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Intercooler upgrade are a must you will heat soak.
Old Jun 12, 2013 | 02:20 PM
brnrdtns's Avatar
Forgot to mention that I have the 997.2 intercoolers.
Old Jun 12, 2013 | 02:22 PM
996tt550hp's Avatar
I would have gone with bigger ones there ok the 997 ones but there only 2.5 inches you really want 3.5 or 4 inches.
Old Jun 12, 2013 | 02:25 PM
raineycd's Avatar
If you turn the key on, does the fuel pump run and pressurize the system? Never really paid attention... If so, may do that to see no leaks.
Old Jun 12, 2013 | 02:42 PM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
They are 3.25" cores.
brnrdtns, target AFRs should be 1.0 on the lambdas (14.7 AFR on gasoline) at idle.
Old Jun 12, 2013 | 03:39 PM
32krazy!'s Avatar
dont make my mistake! make sure the proper plugs are on the proper sensor or injector. the cam adjuster sensor and the #1 injector both use the same style plug and are very close to each other. i mistakenly swapped the plugs and 6 months later i finally have a car with no codes and runs properly. check check and double check!
Old Jun 12, 2013 | 06:32 PM
996tt550hp's Avatar
997 intercoolers are restrictive already seen the test and no they are not 3.25 there less then 3inches i have them in front of me. One run in heat and after that you will be heat soaked.
Old Jun 12, 2013 | 06:46 PM
earl3's Avatar
997.2 on the left. Not a restriction in the least on a mild 18g build. Would you like to see the independent flow testing I payed for?
Old Jun 12, 2013 | 06:51 PM
996tt550hp's Avatar
There both restrictive they have plastic on both ends of each intercooler and no there not good enough for the 18g. I ran them i know. It was a complete waste for to put the 997 intercoolers on.
