Clutch options: Sachs vs clutch master
I've been in contact with both vendors and both have been very supportive in providing info and their experiences. Both clutch kits appear very similar making it a tough choice. I also did a quick search looking for potential comparisons between these two options: Sachs 2.5 vs clutch master fx250 and found little to no direct comparisons for this platform. I suspect few people would have gone through both options given their durability
Essentially, I'm looking for people's real world experience. Particularly, please comment if you've driven either or both, on:
- drivability (stock-like?)
- reliability (up to 550-600)/durability
- if you had the choice to do it again, would you repeat the same choice or try alternative; if so, which one?
- whatever else you wish to mention
Note, my intended use is mostly on the street with occasional DEs; not likely to track.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
https://www.6speedonline.com/forums/...-clutches.html
Do a search on the ERP clutch and you will find much more info.
HI,,I had 2 CMs prior to my current Sachs..Didnt like the CMs...Did threads on it.
Hands down the Sachs better modulation and feel..
But the ERP is going to be my next clutch when needed..
Good Luck
Good Luck
i have the sachs 2.5 in my turbo and dyno'd 510 rwhp. im a drag racer at heart so track use is mandatory! hard launches at 4500 rpm and havent had any slippage. still have the oem slave setup so it feels a bit soft to me.
it was in the car when purchased so ill keep it until it starts to fail. that said like johnspeed and many others erp and gt2 slave will replace it when the time comes, no need to look elsewere
ive got the carbon clutch (triple disk) on my car with their steel flywheel setup.
this clutch loves to be slipped... i can make my car sling shot out of the whole by launching the car at 3000 while riding the clutch..
i love the clutch because its designed to be slipped...
slipping = the key to a great launch.
Get the Sachs, its much better. We put Kits together from Sachs all the time for DE Cars at our Shop.
Thanks to everyone for providing their experience thus far.
Sounds like ERP is the way to go, though at a slightly higher price point that I had initially budgeted. If sticking with my original two options, sounds like a few people had good success with the Sachs kit.
I have CM and engagement is sharp. Its easier to modulate now that I did the GT2 slave but i'd def go back to a beefed up Sachs. I know EVOMS has a nice kit but if my budget allowed i'd go with ERP for an end all solution.
Clutches aren't something you want to keep doing over and over...
Good luck!
Good luck!
I always love it when Vendors jump in with their sales pitch instead of any real info.
Jules where in Canada are you located. You could try out my ERP if local.
I think you will find most of the big power guys have opted to go for the ERP as of late.... Tim941NYC, BlackdonkeyTurbo, Eddie B are the three most prolific HP chasers and they are all running ERP's with over 1000hp and very happy with them. So are the lesser power guys like me.
Pay a small amount if any more for an ERP twin or triple disc and you will have a clutch that will outlast anything else out there. Cary from ERP also stands behind his product!!! No questions there; the other manufactures are not so good with that last issue,
OP does not have 1000hp car. What you are suggesting is more than what he needs. He wants something he can live with everyday. Between the CM and the Sachs kit, Sachs is a better option that will serve to higher tq and be VERY close to stock clutch. Proven, no adventures, no room for error, over and over installed by tens of paying sponsors here which makes these forums available to everyone of us.
If I am over the line, and came off strong and disrespectful, I publicly apologize from you. However, it is unfair to talk down on someone who is making an honest suggestion with the anticipation of genuine help to a customer. In return, if we make a sale, GREAT, if not so be it.
There are 2 vendors chimed in here. Only one made a sales pitch and it was me. Nowadays everybody is emotionally attached to what they have purchased. Especially if it works to the expectation. The otherwise creates a lifetime opposition to the manufacturer and the product. So to say, if you care to ask any questions, I would be more than happy to explain as to why I advise one product over another in this thread.
