GT2 gas tank fit in 996tt?
#31
talk of the 997tt pump in 996tt tank https://www.6speedonline.com/forums/...-limits-6.html, still no answer about GT2 tank=pump?, but based on this thread I'd bet a '7 GT2 pump fits a '6GT2 tank...??
#32
i would go the walbro 450 pump - quite, smaller and fits great. Here is how Taboo and I did it. We used a stainless hose clamp, that we drilled and put a small bolt thru and then clamped around the pump. the bolt had two nuts, which then went thru the side of the basket and held the pump upright and centered like you can see in the photo.
#35
Originally Posted by prodigymb
did you also have to get new lower coolant lines because my gt2 tank did not fit between the oem 996tt hard coolant lines at the bottom.
04-28-2022 12:38 AM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-18-2015 03:42 PM
